This could be fun
13 Oct 2017 20:04 #14178 by kevinross
Brian wrote: The designer suggested a 10A ESC, I thought the 12A would be OK. The HKing props are slightly smaller than the ones suggested too, puts less load on the motor, leaves a bit more juice for the servos...............hopefully.
Hi Brian
The recommended Robbe / multiplex ESC has a 1.5 amp BEC output which i assume they have deemed suitable to power 2 x digital HS 65 servos. The data sheet on these servos says they draw 1/2 amp each at their rated max torque.
Therefore its important to consider the rated BEC output as well as the motor output
13 Oct 2017 20:59 #14182 by Brian
I suppose the setup really determines the power requirements. What occurred to me was that the wings rotate about the spar, so they must be pretty close to being aerodynamically balanced. That would minimise the load on the servos. Perhaps the recommended servos are a bit of an overkill, just to give snappier response.
13 Oct 2017 21:45 #14184 by MikeSeale
Firstly, yes, I'm interested in a group build. I agree that it is a bit expensive, but the quality of Hoellein/Gruner laser kits is second to none and that makes it better value.
Regarding the recommended parts...
I'd imagine that fuselage space will be at a premium and the recommended items will fit - perfectly. I'd definitely get the Hacker motor and HiTec servos. Battery and ESC can be substituted. The reason I'd go with the Hacker motor is I know how bullet-proof they are when used indoors and it would be difficult to find a cheap motor that is going to be exactly the same size and shape. The reason for picking the HiTec servos is that you will need a servo with a tight gear train and good centreing. There might be a good alternative but saving a few quid here is not the right place.
Finally, saving a few quid on a HK spinner and prop is really false economy. Aeronaut products will be balanced and give more power for less current than some cheap plastic and soft alloy alternative
13 Oct 2017 22:25 #14185 by Brian
I take your point about the HKing prop Mike, I suppose you only get what you pay for, and a fiver for a folding prop doesn't really make for a lot of confidence.I can't remember the price of the Hacker A10-7L but it seemed to cost as much as the Gurke kit. I think that powering the model with a PP motor will provide all the adrenaline I can manage, apart from that, there's no merit in using cheap servos. On the radio side, one good thing about Frsky/Taranis is they do a very neat micro receiver, XM+Micro. If a group build does get under way, would there be any merit in asking for a discount for a bulk buy?
14 Oct 2017 10:05 #14188 by kevinross
As mike says - these are precision kits and designed for the recommended parts. However, i would consider the
hobbyking.com/en_us/turnigy-aerodrive-sk...outrunner-motor.html
as an alternate to the Hacker which has the same diameter but only 63w instead of 75w on the Hacker. H/K sell spare shafts and the larger versions of this design have been used successfully.
14 Oct 2017 16:58 #14189 by 4Pedalsfly
Replied by 4Pedalsfly on topic This could be fun
I'm. confused, can someone please clarify what control functions this has ?
Mention as been made of wings rotating around the spar ( aileron function ) what about elevator ?
Thanks
14 Oct 2017 17:14 - 14 Oct 2017 17:16 #14190 by kevinross
4Pedalsfly wrote: I'm. confused, can someone please clarify what control functions this has ?
Thanks
The "mentionings" are correct - both wings twist in opposition on the spar for Rpll and rotate together (with respect to a fixed stabiliser) for Pitch -
All is explained in the attached videos - www.hoelleinshop.com/Planes-Helicopters-...&t=49301&c=171&p=171
The more i see, the more i like - Time to get some numbers together
From what i can see on Der Himmlische Höllein website - postage is free >200 euro - So min 2 kits + some accessories should be sufficient.
Mike Seal ordered the last batch of Impressivo's but not sure if the order was sufficient to gain any discount.
Last edit: 14 Oct 2017 17:16 by kevinross.
15 Oct 2017 00:15 #14197 by MikeSeale
I would like to see if the SK3 motor has a shaft that extends beyond the back of the motor in order to accept a prop adapter/spinner.
15 Oct 2017 07:27 #14199 by Brian
I looked at the HKing site, the video showed a Turnigy SK3 that was a replacement for a 30cc engine. The only difference in motor build is that the outer casing is static. I assume that the motors with high KV numbers are suitable for smaller models. All a bit confusing for a novice in electric flight. Must be a spec sheet on all the motors just a case of finding it.
15 Oct 2017 07:57 #14200 by kevinross
MikeSeale wrote: I would like to see if the SK3 motor has a shaft that extends beyond the back of the motor in order to accept a prop adapter/spinner.
Good point Mike - further investigation shows the replacement shaft is only 25mm long so the answer is no -
Time to create page: 0.368 seconds
