This could be fun
15 Oct 2017 10:26 #14205 by Phil Ford
Replied by Phil Ford on topic This could be fun
Brian wrote: I looked at the HKing site, the video showed a Turnigy SK3 that was a replacement for a 30cc engine.
30cc? This glider is gonna be awesome.......:evil:
15 Oct 2017 11:52 #14206 by Brian
Must admit, I thought it was a bit on the large side to power a Gurke. Quite safe though, AeroNaut don't do a 7 X 4 prop with a huge shaft adapter.
15 Oct 2017 13:35 #14207 by kevinross
Don't know where a 30cc sized motor came from - the link i attached was for
Turnigy Aerodrive SK3 - 2122-2100KV Brushless Outrunner MotorSpecs.
Turns: 6T
Voltage: 2~3S Lipoly
RPM/V: 2100KV
Internal resistance: 0.12 Ohm
Max Loading: 7A
Max Power: 63W
Shaft Dia: 2.0mm
Weight: 24g
Motor Plug: 2mm Bullet Connector
15 Oct 2017 22:37 #14215 by Brian
I saw this one on the HKing site, looks quite close to the A10-7L in performance.
hobbyking.com/en_us/d2826-6-2200kv-outrunner-motor.html
15 Oct 2017 22:59 - 15 Oct 2017 23:01 #14218 by Chris001
Replied by Chris001 on topic This could be fun
Just going back to the servos, the recommended ones are the HiTec HS-65MG & HS-65HB it hadn't occurred to me, but these are the analogue models, I wonder if these are being recommended because the digital versions, HS-5065MG, might draw too much current from the BEC. It looks like most 10Amp ESCs come with a 1Amp BEC like the one recommended.
Havign said that the specs on HiTec's site look Identical, well actually the idle current of the digital is lower than the analogue.
HS-65MG
HS-5065MG
I've actually got a couple of HS-5065, so I'm tempted to try those to start with at least.
Last edit: 15 Oct 2017 23:01 by Chris001.
15 Oct 2017 23:58 - 16 Oct 2017 00:03 #14220 by MikeSeale
Motor might have similar performance but the motor shaft will need reversing.
...and it weighs about twice that of the A10 and is a bigger diameter.
Last edit: 16 Oct 2017 00:03 by MikeSeale.
16 Oct 2017 00:02 #14221 by kevinross
Chris001 wrote: Just going back to the servos, the recommended ones are the HiTec HS-65MG & HS-65HB it hadn't occurred to me, but these are the analogue models, I wonder if these are being recommended because the digital versions, HS-5065MG, might draw too much current from the BEC. It looks like most 10Amp ESCs come with a 1Amp BEC like the one recommended.
HS-65MG
HS-5065MG
Chris - I also assumed the HS65 was digital but reviewing the specs again - The analogue unit draws max 600ma each but the digitals can draw 1200ma so Yes you need a strong BEC to use digital. I suspect wing twisting in tight turns may draw high current.
16 Oct 2017 00:08 #14222 by MikeSeale
Too much worrying about things that don't matter. A 1A BEC will be fine for 2 servos.
16 Oct 2017 08:18 #14224 by DavidTappin
Replied by DavidTappin on topic This could be fun
Chris mentioned that
I've not met him, is Havign a new member? He sounds foreign.
16 Oct 2017 08:36 #14225 by Chris001
Well you don't think I'm daft enough to put my name to some information that might prove to be wrong do you, Havign is my convenient scapegoat :evil:
Time to create page: 0.462 seconds
