BVM Mig.15
04 Dec 2016 20:38 #11033 by simondean
Replied by simondean on topic BVM Mig.15
If anyone can turn this into a top model Pete you can. John is in safe hands.looking forward to the build thread once you get started. B)
06 Dec 2016 18:52 #11043 by Phil Ford
It's gone very quiet at Pete's end. Either he is having a well earned break or he is still reading the manual or looking for part no 209a/ii left side. :lol:
06 Dec 2016 19:45 #11046 by Chris73
Replied by Chris73 on topic BVM Mig.15
flyingpete wrote: Chilver aviation will be going on Christmas shutdown this week so not much will happen for a couple of weeks. f15
06 Dec 2016 19:58 #11047 by Phil Ford
Oh Yes! Forgot. ;)
07 Dec 2016 15:14 #11057 by flyingpete
Christmas tree up, outside lights done and extra sockets in the bungalow done I need a modelling fix B)
The fibre glass canopy hatch requires the glazing panels to be cut out, so to leave just the frame ready to glue the clear panels in at a much later date.
This is a really tricky job that has to be done stone cold sober :( as one bad slip with the dremel and its game over.
Firstly undercut by 2mm all the straight lines with a cutting disk, stitch drill the corners.
Once all cut out, clean up with a drum sander on low speed to within 0.5mm of the finished edge. Using perma grit large and small files finish to the final size.
07 Dec 2016 15:16 #11058 by flyingpete
Canopy frame finished
07 Dec 2016 19:42 - 07 Dec 2016 19:45 #11066 by flyingpete
Next up are the speed brakes or speed boards. As these are designed to be deployed in flight on the model thay are made from carbon fibre for added strength . First job is to cut them from the marked sheet using the same method as before and add the 1/8 ply stiffners using med cyano.
Last edit: 07 Dec 2016 19:45 by flyingpete.
  • JRI
07 Dec 2016 21:55 #11070 by JRI
Good to see you are making the most of your 'down tools' time Pete ;)
There seemed to be a lot of advice and addendums associated with the speed brakes. Would these be deployed with the flaps typically? And is there enough room in the fuselage for small hitec mg servos to operate the brakes, and should we be worried about the proximity to the thrust tube (heat affecting the servos), and should the brakes be on a slider switch or just slam to full deployment?
07 Dec 2016 22:08 - 07 Dec 2016 22:15 #11071 by flyingpete
BVM recommends that the air brakes are deployed with full down flap. No problem with heat from the exhaust as everything is covered by the heat blanket. I plan to use thin mg hitec glider wing servos.
Last edit: 07 Dec 2016 22:15 by flyingpete.
08 Dec 2016 08:08 #11072 by Phil Ford
flyingpete wrote: I plan to use thin mg hitec glider wing servos.
Best of luck with sourcing HiTec slim wing mg servos Pete. They are like gold-dust to find. I had to back order 2 of 4 for my 3m glider. Took 6 weeks. Wheelspin Models got them for me.
Nice job of cutting the canopy. No option to make mistakes Pete so a steady hand. Good on yer! ;)
