BVM Mig.15
09 Dec 2016 21:15 - 09 Dec 2016 21:16 #11118 by flyingpete
Thanks Dave, but does that go for your F15 as she will look pretty sexy in the digital cammo scheme B)
Last edit: 09 Dec 2016 21:16 by flyingpete.
  • JRI
12 Dec 2016 08:05 #11152 by JRI
A red nose is required (to go with it's owner :whistle: ) ...
13 Dec 2016 19:49 #11160 by flyingpete
Last job before I reluctantly shut the workshop door's for Christmas are the underwing tank's/pylons.
Very strange from BVM is that the pylons are made up from ply and balsa and not f/glass.
Anyway first job is to drill 6mm holes top and bottom for the alloy guide tubes. Make up the pylons from 3/8 balsa and 1/64 ply and scribe into the wing tank and underside of wing. Once happy glue to the protruding alloy tubes.
Next job is make up the fins with ply core and balsa top and bottom. Cut mounting slots with a dremel and glue fins to tank sides
The fixing in the wing is a 6 mm threaded tube which will be epoxied in place and 4/40 bolts screwed up through the alloy tubes to secure.
Filling and painting will be next job
13 Dec 2016 19:51 #11161 by flyingpete
Few more
14 Dec 2016 16:51 #11163 by Phil Ford
Going on in leaps n bounds. Well earned break too.
14 Dec 2016 17:26 #11165 by DaveBright
Replied by DaveBright on topic BVM Mig.15
Lovely stuff
14 Dec 2016 19:41 #11166 by 4Pedalsfly
Replied by 4Pedalsfly on topic BVM Mig.15
Great work Pete - Look forward to seeing your next postings.
Enjoy the festive season.
15 Dec 2016 16:36 - 15 Dec 2016 16:37 #11173 by flyingpete
Sneaked a couple of jobs in today.. Cut the slots for the nose gear hinges, removed the single hinge pins and made up a full length pin. Roughed up the inside with some 80 grit and glued with med cyano
Last edit: 15 Dec 2016 16:37 by flyingpete.
15 Dec 2016 16:48 #11174 by flyingpete
Next little job was the front f /glass inlet pipe.
This needs some extra strength but without any weight gain as the main battery and radio will sit on a ply plate on the inlet.
I marked it in four places and using 6mm carbon tow wrapping it around four times and then soak the tow with thin cyano.
This resulted in immense strength but no weight gain. It's worth a mention that this must be done outside as the fumes from the cyano are pretty horrible.
15 Dec 2016 16:59 #11177 by DaveBright
I thought you had 'reluctantly shut the doors of the workshop' already? :) this will done by Christmas Eve. John are you sticking with the cortex or saving overall space and going for a powerbox mercury?
Time to create page: 0.408 seconds
