5 years 2 months ago #23078 by Brian
The dot on the cam gear was significant, the trick is to eyeball the dot to line up with the (imaginary) centre line of the push rod tube. A bit difficult as the gear teeth are cut diagonally (the gears mesh with the shafts at ninety degrees) and as the cam gear is lowered into place, it rotates, not a lot, but enough to make a difference between the engine just running, or running properly. With the engine sorted, or so I thought, I removed the Panic's very tired NiCd flight battery and fitted a shiny new replacement from Overlander (Buy British!). Some time ago I bought a pair of Spektrum AR 8000 receivers, I bought two to get 20% off. Wish I hadn't. I fitted the first Spektrum AR 8000 into the Panic, it bound OK, but there was no output to the servos. The second AR8000 was exactly the same. Seems I've been conned and the "Spektrum" receivers are a "lookalike" from a nasty Chinese outfit known as KoKo. Fitting a genuine Spektrum receiver cured the problem. Phew! I know I should be getting on with the Kadet, but its far too hot in the shed, and messing around with a newly acquired four stroke engine attached to a flyable Panic airframe, well...what's not to like?
5 years 2 months ago #23080 by Phil Ford
Brian Jackson wrote: The dot on the cam gear was significant. A bit difficult as the gear teeth are cut diagonally (the gears mesh with the shafts at ninety degrees) and as the cam gear is lowered into place, it rotates, not a lot, but enough to make a difference between the engine just running,
Slight deviation - And people used to moan at me because of the time taken to set camshafts on the old Mercedes 250 & 320 diesels unless you have the expensive setting tools only supplied by Mercedes. ;)
So, Brian have you got it running?
5 years 2 months ago #23082 by Brian
Have I got it running? The SC started easily and ran, I'd left the main and slow running needles alone, I'd flushed the carb with new fuel and blown it clear.
It didn't rev above 7600 and it wouldn't idle without the glow driver connected. I reset the slow running needle, I left the main needle at 1 1/2 turns open as the manual states. I re-set the throttle with a pin in the air intake. I removed the fuel tank and cleaned it and the fuel lines. The tank bung was a bit loose and had been leaking. The engine is an easy starter, but runs slowly and the idle is erratic. I changed the SC plug for an OS F, no change in performance.
The engine doesn't have much compression, but its ringed so that's to be expected. Can't really do much with it as its hot and the neighbours have their windows open and don't appreciate the beauty of a tuned engine on song.
5 years 2 months ago #23083 by Brian
Checked the prop this morning, its 12" X 8", should be 11" X 6" or 7". Might make a bit of difference to the running.
5 years 2 months ago - 5 years 2 months ago #23084 by
Replied by on topic Back to Basics
Glad you managed to salvage the SC. It's been parked up for at least 15 years Brian, so a problematic idle until it's fully awake is, I suppose, understandable.
Last edit: 5 years 2 months ago by .
  • throttletothewall
  • Senior Member
  • Senior Member
5 years 2 months ago - 5 years 2 months ago #23087 by throttletothewall
Replied by throttletothewall on topic Back to Basics
Brian in my experience an old engine like that may well be suffering from the needle valve O ring going hard/brittle or being worn. I have had a lot of old (15 years+/many hours use) 4 stroke engines over the years that developed idling problems and sometimes starting to cut out at full throttle, whilst in the air, nearly all of which were eventually cured by replacing the needle valve O ring after checking through all the other things you have been going through with the SC and fuel system. Might be worth a look, it is usually evident by the outside edge of the O ring looking a bit flat rather than rounded.
Last edit: 5 years 2 months ago by throttletothewall.
