07 Apr 2020 09:46 #21996 by Phil Ford
Brian wrote: Its a ploy! You're pretending to be doing something with a model, when you really plan to publish a recipe for Wheat Bisk based cupcakes.
No cupcakes it's not. Wing top n bottoms cut out and .......um that's it so far. :lol: Got to hang it out for two months at least.
16 Apr 2020 18:49 #22116 by Brian
Since my last posting I've hit another snag. My building board has become distinctly concave. No longer is it pristine and very flat, it is most decidedly concave and extremely convex if I turn it over. It was quite expensive when I got it from SMC some years ago, I think its a SIG product, I was impressed by how easy it was to pin things while building. Now I'm stumped. For the past week or so (time just goes by and the numbers change and nothing happens) I've had a load of lead weights on a big piece of straight timber, all perched on the board (convex side up) in the faint hope that it'll pull it straight. In the "Good Old Days" I used to build on a drawing board which was so old it had an Air Ministry stamp and a reference number on the back which dated the board to 1941. Sadly I became interested in foam wing cutting, and the drawing board was sacrificed on the altar of "progress", and was converted into a base for a foam cutter. I wondered whether "ironing" the bent board with a steam iron would invite it to straighten itself out. Its all very frustrating. Wish I still had my trusty old drawing board. However, it isn't all bad, my wife has kindly ditched meusli (which comes in floppy bags) for breakfast , and with no fuss at all has gone over to Corn Flakes. In a couple of weeks or so, I'll have enough thin card from the boxes for the Kadet's templates.
17 Apr 2020 19:04 #22135 by Brian
Seems that the weather had something to do with the building board being less than flat. I don't know if the weights did the job, or perhaps it was a combination of weight and humidity. Whatever it was, the board was flat enough to start the Kadet build this morning. The original has 3/32" balsa sheet covered fuselage, the side sheets are pre-printed with the positions of spacers longerons etc. The longerons are quite robust (1/4" square hard balsa) so I'll ditch the cladding and perhaps add some diagonal bracing instead. The photos are of the main fuselage structure, a couple of scanned formers, and finally a shot of the tail end. I'd been building the model without even beginning to think of altering the structure (apart from the sheeting), when I look at the tail end I wondered why the designer hadn't carried the tail plane support to the end of the fuselage profile and similarly with the lower longeron. All I did was slavishly cut the 1/4" balsa sheet to finish the end of the fuselage. Anyway, its too late now as the parts for the second side are all shaped ready to assemble. For the eagle eyed among you, I'd like to point out that the dark lines along some of the joints are not gaps, they are only the remains of the original marking out. I've started to use an old roller ball pen and the ink line is a bit generous.
I had just two small snags today. The scanner and the printer normally get along quite well, today the print was smaller than the original scan. Going back to the old set-up using Windows 7 put things to rights. The other thing that didn't go quite to plan was that I couldn't find the photos on my camera, that was caused by finger trouble on my part. I'm too lazy (and mean) to change the onboard battery that keeps date and time when the main battery is being changed. This means that date and time have to be reset every time the battery is swapped around. The camera had turned itself into a time machine and hid today's shots in 01-01-2002, never thought about it before but the camera is now eighteen years old, and I still haven't read the manual, only the quick start guide.
18 Apr 2020 19:52 #22153 by Brian
The second side of the Kadet was completed yesterday evening. Today the two halves were parted with a razor saw. The right hand side of the fuselage is pinned and the first former is in place. The second former is glued and pinned and will be fitted tomorrow. I cut the templates for the firewall and first former, somehow they didn't look quite right. At first I thought it was due to misalignment of the drawing "tiles", but I found that the centre lines of the formers were 1/32" out. I hope you understand that I'm using good old fashioned Imperial dimensions. The drawing of the Kadet is American and there isn't a millimetre in sight! It was so nice to make a part that was 5 11/16" high and 3 7/16" wide.
19 Apr 2020 10:30 #22160 by Phil Ford
Thumbs up to progress . Nice "man shed" by the way.
19 Apr 2020 11:24 #22161 by MikeSeale
Looking good. Keep posting your progress. I find that it spurs me on to complete things when others know what I'm building. The opposite is that if I do not post a build log I can (and do) take big breaks and it takes a lot longer to complete.
19 Apr 2020 18:05 #22175 by Brian
Thanks for the encouragement Mike and Phil, I've nearly reached the stage where I really must stop and tidy up a bit, however, the habit of a lifetime is hard to break and I just can't bring myself to tidy as I go. Today was quite eventful, it was so nice to be able to have the shed door open and not have a frisky breeze re-arranging the shed contents, however there was a short drama when a queen wasp decided to make a takeover bid and use the shed as a nice safe place to build a new nest.
Waving a rolled up newspaper persuaded the wasp that things weren't quite as tranquil as she thought, and it flew out, but stayed around that part of the garden for the best part of an hour before finally giving up and literally buzzing off. The only casualty from the encounter was the neat pile of shavings and balsa dust that I'd roughly scraped together with a view to getting serious with dustpan and brush at the break for lunch, the bits were all over the bench, perhaps I'll have a quick whizz round with the vacuum cleaner before tea.
The fuselage sides have now been introduced to the two main formers which are made from 1/4" X 1/2" hard balsa.The original Kadet had a 3/32" ply front former, I didn't have anything that size so I laminated a piece of hard 1/16" sheet and 1mm ply, cut and sanded the laminated former, and glued it to the front face of the front main former. With the formers in place, I was able to glue the front 1/4" balsa sheet sides for the fuselage front end/tank bay. Once again, I should have sat down with the drawing and revamped the structure to make it easier to build, as it is I'm having to draw up parts that would have been printed sheet when the model was first introduced. The first job for tomorrow will be to cut and shape the firewall, then I'll have to decide what to use to power the model. SIG recommend a .19 to .40 two stroke, my original thoughts were electric, but subsequent rummaging didn't turn up a motor that would be powerful enough, but it did unearth an OS FS.52 fourstroke that somehow avoided being sold off during last year's monster clear-out. I do have an Irvine .46(NIB) but I think that wouldn't be in the spirit of the Kadet, which was designed as a slow and gentle flying trainer for three channels, the drawing for adding ailerons looks like an afterthought, and I'm not sure whether to build those, or modify the wing as the more modern ARTF Kadet Senior. Anyway, I'll concentrate on the fuselage for the time being.
20 Apr 2020 17:13 #22190 by Brian
No dramas in the shed today thank goodness, it was a bit windy so I had to keep the door shut, by four this afternoon it was far too warm to carry on. Nose formers and stringers were fitted, top edge of the windscreen mount was added. Made up a piece of sheet for the nose by laminating some pieces of scrap 1/32" sheet. The method I used was to tape the sheets edge to edge, invert and apply glue to the joints*, apply thinned PVA to both mating surfaces and allow to dry. Place the glued surfaces together and press firmly with a very hot iron. Gives a strong piece of sheet which is also very flexible. This made sheeting the front end quite an easy task. Sheet was held in position with masking tape.
Note *. When making wide sheets for wing skinning etc. I tidy up the sheet edges to give as near an invisible joint as possible, tape the sheets together, invert them, then slide the assembled sheets to the edge of the bench so that the first part is flat on the bench and the rest of the taped sheets hang straight down. Apply a thin film of your favourite PVA or Aliphatic glue to the joint, then slide the first sheet back along the bench and do the same on subsequent joints. I "squeegee" the joints with an old bank card to get excess glue from the sheet surface. Most times the sheets need no further attention, sometimes they need a bit of inviting to stay flat, in which case use a sheet of polythene and something flat to weigh the sheets down while the glue dries.
20 Apr 2020 23:43 #22194 by 4Pedalsfly
Looking good Brian, your method of laminating balsa sheets is interesting,allowing the
glue to dry and then taking the iron to them is a new one on me.
I.C or Electric ? that O.S four stroke would sound good.
21 Apr 2020 08:33 #22198 by Brian
I used thin PVA glue and a hot iron to laminate formers for lightweight free flight rubber models back in the '90s. I did it because I wanted to find a way of making formers that had those irritating notches for stringers. You know what happens, it doesn't matter how sharp the balsa knife is, or how carefully you cut the notches, the balsa grain is always "wrong" at some point and the corner of the notch drops off. My wife was doing some renovations to a dress I think, or perhaps it was a curtain, anyway she was using some white thready looking tape which when placed between layers of fabric and ironed with a hot iron, bonded the fabric enabling it to be held firmly while being sewn together. I scrounged some tape and made a couple of trial formers from 1/32" sheet. I was surprised to find how effective the tape was. The formers were successfully notched with no damage at all.Then I read somewhere that the tape was PVA based, so I bought some PVA glue and experimented, finally coming up with the thinned glue and very hot iron. This method worked very well on tubular fuselages laminated from two thin sheets of balsa, these were formed hot around a piece of copper water pipe. As the years went by, I found as so many others before me, that for a free flight enthusiast, the trees got higher and the gorse much denser and retrieving became an exhausting process. R.C. flying looked to be a promising alternative, so I gave it a try and became hooked. At first I floundered quite badly, I couldn't get to grips with building models from hugely thick sections of balsa, and as for the size of the engines! When you've been flying models made from light thin sections, and using tiny engines of .049 size, everything seemed disproportionately robust! Finally I became more comfortable with 1/4" ply formers and 1/8" balsa sheet clad fuselages, but I found it really hard to use heat shrink film for covering. The day came that I needed some Balsaloc, fortunately I had a new jar of it, unfortunately it was over a year old and had solidified. In desperation I brushed thinned PVA on the edges, and after it had dried, gave it a light sanding and another coat. The film went on alright, and I've never used Balsaloc since. There is a covering material called "Polyspan" its a strange polyester fabric that looks like vintage Modelspan, when doped its extremely tough and isn't all that heavy, goes on quite easily with PVA and heat, also goes round compound curves if taken gently.Another material from SIG called Koverall is a woven fabric which can be stuck using PVA and heat.
When ironing on the previous two coverings which are porous until doped, to prevent the iron from becoming all "gooey", I place a strip of woven teflon baking sheet along the edge to be ironed, this also works well if laminating very thin balsa sheet which tends to let the glue migrate.
Time to create page: 0.430 seconds
