23 Apr 2020 15:49 #22242 by Brian
I take your point Simon, I'll wear sackcloth and ashes for ten minutes next Friday week. I'll have a rummage through my photos. Somewhere I've some shots of my WOT 4 Mk 1. A thing of beauty and has 1" dihedral under each tip, as per the manual,(half an A4 sheet) which was written by Chris Foss years ago. When I look at a WOT 4 now, the straight wing makes me think that the model has had a hard landing and done some mischief to the centre section. Finally, I think its the Acrowot that has its wing built upside down so that the wing section taper is on the underside and gives the appearance of "dihedral", or it might have been my scratch built CAP 21.Memory not quite what it used to be. Not a lot of time on the Kadet today. Made up the hardwood blocks for mounting the main U/C, hacked some blue foam and glued the pieces together to make a plug for the Kadet's cowling.
  • Simon O
23 Apr 2020 16:34 #22243 by Simon O
Replied by Simon O on topic Back to Basics
I also had a mk1 (I think) Wot4 in 1979? with a 'planform' wing. I'm sure it didn't have dihedral even in those days. Yours must have been a very early example Brian
23 Apr 2020 17:48 #22245 by Brian
At the time, the WOT 4 was some pre-cut (bandsawn) pieces, a veneered foam wing and a single sheet of paper with a couple of diagrams and a few dimensions and the build instructions. A few years ago, some enterprising chap drew it up, and sold the plan on a website. I don't think Mr. Foss was at all pleased. The profile of the WOT 4 was a bit different, much blunter and unswept fin and rudder, and I think the elevator had a fragile "balance" tab on each end, the fuselage seemed to be a bit deeper too.
23 Apr 2020 17:58 #22246 by Brian
Getting back to the SIG Kadet, I fitted W bracing as the fuselage isn't going to be clad in balsa sheet, the U/C mounting block is glued in, and the foam block is marked out ready to start making a horrendous mess of blue polystyrene dust tomorrow. I'm having spinach for lunch for the next few days, perhaps I'll have enough strength by then to be able to heave the 4mm U/C wire into a pair of main landing gear legs. I have two lengths of wire, so with luck I'll eventually end up with a "pair" of usable legs.
23 Apr 2020 18:11 #22247 by JonTappin
Replied by JonTappin on topic Back to Basics
Simon O wrote: Brian! What do you mean a high wing model without dihedral looks wrong?!!!
Please, treat yourself to a mouthwash! Don't you remember the beauty, grace, unsurpassed flying characteristics of probably one of the most popular models ever designed and flown?!!! None other than of course the incredible, unsurpassed WOT4!!!
Really?
"beauty, grace, unsurpassed flying characteristics", you sure you're thinking of the Wot4 Simon???? ;)
23 Apr 2020 18:21 #22248 by MikeSeale
When I started flying (1980) a company produced a trainer called the Gnatty ()maybe Natty). Based on the Folland Gnat, you could build it with dihedral and 3-ch, no dihedral and 4-ch or anhedral of better aerobatic performance. I remember seeing them fly at Sandown and they looked ok in the air.
  • Simon O
23 Apr 2020 19:18 #22249 by Simon O
No Jon but it wound Brian up!
23 Apr 2020 19:58 #22250 by Brian
Rotter!
23 Apr 2020 20:46 #22251 by JonTappin
MikeSeale wrote: When I started flying (1980) a company produced a trainer called the Gnatty ()maybe Natty). Based on the Folland Gnat, you could build it with dihedral and 3-ch, no dihedral and 4-ch or anhedral of better aerobatic performance. I remember seeing them fly at Sandown and they looked ok in the air.
I remember them well Mike, the anhedral one looked quite good.
I remember someone did a Wot4 clone with anhedral, it didn't look good!!
24 Apr 2020 07:42 #22252 by Brian
Here's one somebody made earlier.
Time to create page: 0.392 seconds
