Rubin
11 Apr 2020 00:35 - 11 Apr 2020 00:38 #22051 by MikeSeale
Cowl removed from the vacuum bag. Peel ply removed. Foam and packing tape removed.
Pictures are in a random order because the forum s/ware is f*#?$ed
Last edit: 11 Apr 2020 00:38 by MikeSeale.
11 Apr 2020 00:39 #22052 by MikeSeale
And it fits...
11 Apr 2020 08:18 - 11 Apr 2020 08:19 #22053 by kevinross
looking good mike but aren't your standards slipping with residual building waste on the work bench ! :blink: :blink:
Last edit: 11 Apr 2020 08:19 by kevinross.
15 Apr 2020 16:45 #22095 by MikeSeale
A quick update on progress over the past few days. Lots of little tasks have been completed and were not photographed but the Rubin is nearly ready for covering.
Elevators will be controlled with two mini servos in the tail. Rudder will be a closed loop.
15 Apr 2020 16:47 #22096 by MikeSeale
I was planning to do some vacuum forming and spent a several hours making a vacuum former. But the frame warped as soon as it went into the oven...so that was a waste of time - although I do now have a sanding box which will come in useful.
15 Apr 2020 16:49 #22097 by MikeSeale
So the canopy is now going to be a fibreglass one painted black. If I don't like it I will revert to sourcing a canopy later. I did a much better job covering the canopy in parcel tape because I cut it into narrow strips that are much easier to stretch and go around compound curves.
15 Apr 2020 16:50 #22098 by MikeSeale
And the retracts wells are done.
15 Apr 2020 17:48 #22102 by Phil Ford
Mike I know you are careful with cash ;) but I bought one of these albiet the A5 version to make nav light lenses and it is very well made. Wished I had ordered the A4 version. The Guy, Mike (another Mike) makes larger versions, you might be interested.
www.ebay.co.uk/itm/A4-Vacuum-Forming-Kit...-4-inch/283829802298
15 Apr 2020 18:45 #22103 by MikeSeale
Thanks, Phil. I think my biggest problem was the plastic I was trying to use...a 2l bottle. This plastic has already been stretched in the blow moulding process and it shrinks and distorts the frame as soon as heat is applied. His biggest kit will only just do a Rubin canopy and is a lot of money for a few pieces of wood that I could cut myself. So, yes, I am careful with cash and won't be buying.
15 Apr 2020 20:40 #22104 by kevinross
MikeSeale wrote: I
because i look at the pics before i read the text my initial thought was "Mikes made a great sanding box"
PS hasn't JB got a vac forming tool
Time to create page: 0.755 seconds
