Curare 60 E
09 Apr 2020 16:25 #22024 by Phil Ford
Rudder and elevator servos. My Curare GP's throttle servo (micro type) is custom mounted elsewhere to how Jon's is. This leaves the front servo hole for the rudder pull pull. My EP Curare rudder and elevator servos are mounted the same as the GP. to allow clearance for the pull pull wire and wire couplers, the elevator servo is raised up slightly on some ply pads. There is very small clearance between the servo arms and the side of fuselage.
Flaps/Snap flaps I did the same as Jon had except I used collets to secure the bent wire - also makes it easier for adjustments rather than keep unclipping the clevises. See images.
  • Simon O
10 Apr 2020 09:10 - 10 Apr 2020 09:23 #22032 by Simon O
Replied by Simon O on topic Curare 60 E
CURARE WEALTH WARNING!
If you read the article Jon wrote, you may be tempted!
Think twice before you read the excellent article that Jon wrote and has attached to this forum subject about building, setting up and flying the Curare!
Having the components of the model spread out in front of me and reading the article that Jon wrote has inspired me to get on and assemble it.
Jon, if you still feel inspired to write another excellent piece, please write a user manual for the Futaba 18MZ transmitter!
Futaba MZ owners world wide will be so grateful! You never know, you could have a best seller on your hands to rival the Harry Potter books. :unsure: :ohmy:
Last edit: 10 Apr 2020 09:23 by Simon O.
10 Apr 2020 11:00 #22035 by JonTappin
Replied by JonTappin on topic Curare 60 E
I appreciate your kind words Simon, however I've only ever written about stuff I kind of understand, Futaba programming is definately not one of those subjects!!
10 Apr 2020 12:25 - 10 Apr 2020 12:25 #22036 by Phil Ford
JonTappin wrote: Futaba programming is definately not one of those subjects!!
And nearly all of us too!
You will love the Curare Simon. No more worrying about high winds, cuts thro 'em, so no excuses. :lol: Certainly got a bargain there though with retracts included. Of course that is depending how much you paid for it. ;)
Last edit: 10 Apr 2020 12:25 by Phil Ford.
10 Apr 2020 23:24 #22049 by 4Pedalsfly
Replied by 4Pedalsfly on topic Curare 60 E
Phil - You will probably get the same answer Susan got when she saw the big box delivered !!
Simon must have great domestic negotiation skills to be adding such superb aircraft to his fleet.
Looking forward to seeing 3 Curares flying in formation.
  • Simon O
11 Apr 2020 08:28 - 11 Apr 2020 08:46 #22054 by Simon O
I find saying £49.99 usually attracts a lesser degree of horror when I'm asked of the cost of most models! However, I did have to apply a slight increase to the price I acquired the Boomerang Elan for.
When I'm asked these indelicate questions, I often refer to the galactic range of shoes and hand bags that Mrs O has acquired. The conversation thankfully normally moves on to more mundane subjects from then on.
It's all a matter of scale Colin
Last edit: 11 Apr 2020 08:46 by Simon O.
  • Simon O
12 Apr 2020 18:52 #22059 by Simon O
Well, I've been putting some time in on assembly of the Curare the last couple of days. Which is very unlike me, I usually take weeks from getting a model to starting assembly. Strange times we now live in.
The instruction manual along with the article Jon T wrote when he assembled his example have made progress pretty straight forward so far except for getting the flaps working.
The right hand flap control rod was seized almost solid in its tube. I tried all sorts of manipulation without success. In the end, nothing for it but to carefully peel back the covering, with a scalpel cut a V section out down to the tube and expose the tube. Then I sliced the tube open along its length which immediately allowed the control rod to move freely. Then I glued the V piece of balsa back in with PVA along both sides of the V and when set lightly sanded the balsa V section above the tube to smooth it out. I then ironed the covering back into place and hey presto, flaps now both working fine!
Wings fitted with retracts and ailerons, then glued wing halves together and left them for the glue to set.
Fitted the switch for the on board battery and attached the motor box to the bulkhead. Next job is to make up the linkage for the flaps and get ready to start on the tail.
Happy Easter!
13 Apr 2020 09:54 #22060 by Phil Ford
Progressing well Simon. ;) Regarding the flap torque rod , they can be a pain. I smeared lightly Vaseline of the rods to reduce chances of epoxy getting into the rod tubes. Especially when you have to glue torque rods and insert CA hinges or any hinge all at the same time.
13 Apr 2020 11:18 #22063 by Brian
Replied by Brian on topic Curare 60 E
Simon, if you're going to use rude words like "Instruction Manual" I'm not going to read your article so there!
  • Simon O
13 Apr 2020 13:01 #22065 by Simon O
Brian I usually use Instruction manuals to stand my tea on! Haven't you seen the state of my models!
Time to create page: 0.520 seconds
