Curare 60 E
21 Apr 2020 19:42 #22209 by MikeSeale
Replied by MikeSeale on topic Curare 60 E
Well done. Regarding the wiring...sometimes you have to accept that it looks messy until you screw the wing on.
22 Apr 2020 07:14 #22211 by Brian
Replied by Brian on topic Curare 60 E
Patience Simon! If your Curare flies as good as it looks...........
I thought ARTFs were easy peasy , now I know different thanks to your posts and photos.
Nice one.
22 Apr 2020 13:08 #22216 by Phil Ford
Good stuff Simon. Looks like mine....:lol: I had issues too with the canopy and to this day only one screw lines up. Which is fine by me because if there is a reason (fire or similar) I may have a chance to get the pack out. :unsure: Hence another mod I did a long time ago. A pair of 10mm magnets. On the canopy they are just stuck on. Their opposite numbers are recessed back by gluing an extra ply former. The other reason was if you forget (or get distracted) to fit the screw the canopy will stay there - don't ask how I know but lucky there was no rape at the time
22 Apr 2020 13:10 #22217 by Phil Ford
MikeSeale wrote: Well done. Regarding the wiring...sometimes you have to accept that it looks messy until you screw the wing on.
That's what I told him too. ;)
  • Simon O
22 Apr 2020 13:23 #22218 by Simon O
Replied by Simon O on topic Curare 60 E
I've already got some magnets Phil, I may do as you have. I'm a bit worried when you say your Curare looks Like mine. If you have some paint lying around, perhaps you would be kind enough to put your name on yours, in case of mistaken identity! Nothing too fancy mind!
22 Apr 2020 13:30 - 22 Apr 2020 13:31 #22221 by Phil Ford
Simon O wrote: I've already got some magnets Phil, I may do as you have. I'm a bit worried when you say your Curare looks Like mine. If you have some paint lying around, perhaps you would be kind enough to put your name on yours, in case of mistaken identity! Nothing too fancy mind!
It won't get mistaken - mine has got underside wing tip patch with the wrong colour and the fuselage got one too. (fuselage got broke in two) But with both in the air that might be interesting/exciting.:lol: I will think of something before the big day - possibly some strobes.
Last edit: 22 Apr 2020 13:31 by Phil Ford.
22 Apr 2020 13:46 #22224 by Chris73
Replied by Chris73 on topic Curare 60 E
Or learn to make you own extensions leads, then everything can be the perfect length and kept nice and tidy;)
