Stearman build
20 May 2020 19:31 #22569 by JRI
Crikey, that is a complex hinge line - do you know if there was an aerodynamic reason to make it so Kevin?
20 May 2020 21:35 #22571 by kevinross
JRI wrote: Crikey, that is a complex hinge line - do you know if there was an aerodynamic reason to make it so Kevin?
The problem is created because the spar depth tapers at the tips. These pics on the unfinished elevator show what it would look like without that reverse cone shape. So there might be an airflow and drag issue but i suspect its more down to aesthetics.
23 May 2020 21:46 - 23 May 2020 21:47 #22585 by kevinross
Ive now completed the stab & elevators with all the shrouded hinge points. The central pivot wire is secured with this m2 screw. I do like the full and free movement which can be achieved with this hinging method.
Last edit: 23 May 2020 21:47 by kevinross.
23 May 2020 21:48 - 23 May 2020 21:49 #22586 by kevinross
All the tail feathers are now finished and ready for covering but a "BIT" more construction first
Last edit: 23 May 2020 21:49 by kevinross.
23 May 2020 21:54 #22587 by MikeSeale
Replied by MikeSeale on topic Stearman build
Looking good, Kevin. I might have missed it in an earlier post, but how big is this model?
23 May 2020 23:31 - 23 May 2020 23:43 #22590 by kevinross
its 1:4.3 scale, 89" span and will be at 25lbs + depending on how much more metal i add.
Last edit: 23 May 2020 23:43 by MikeSeale.
24 May 2020 06:41 #22591 by Brian
Would you be interested in one of these Kevin?
24 May 2020 09:33 #22592 by kevinross
thanks Brian but scale models that dont go Brum Brum arnt really my thing.
24 May 2020 15:56 #22593 by Brian
I thought perhaps Pop Bang Chuggga-Chugga would be more realistic Kevin. The photo shows the 3d printed engine wrapped around a brushless motor (UGH!).I wondered if you could use the front part of the 3D "engine", just to hide the noisy, hot oily lovely lump that drives the prop.
24 May 2020 20:35 #22594 by kevinross
Sorry Brian, i totally misunderstood your post. If your saying you could 3D print dummy cylinders i would be very interested. Here's a pic of a scale build from the RCSB builders forum. The model is virtually the same size as mine but this "kit" version is well oversize.
Most PT-17's were made with 9 cylinder Continental, some with a 7cylinder Jacobs (which most models copy for simplicity.
I'm fitting a 3 cylinders Saito so its unrealistic to blend scale dummy cylinders to the original formats, So will have to cheat a bit and go for 6. My plan therefore get 3 x 3-D printed copies of the Saito and mount in between each cylinder. That will fill an empty space and with some careful plan to the rear of the dummy cylinders i hope to improve air flow & cooling
So if thats something you could help me with i would be very interested but i am a few months away at the moment.
Time to create page: 0.390 seconds
