Stearman build
03 Jun 2024 11:04 #26821 by Phil Ford
A hell of a lot of work Kevin to achieve the basic cowl, etc.
I wonder if someone has a mould laying around gathering dust somewhere in the world that may have saved you some time.
07 Jun 2024 19:03 - 07 Jun 2024 19:05 #26824 by kevinross
The concept seemed quite straightforward 4 yrs ago - How naive i was
Amy way here is the initial placing / fitting of the forward cowl . I had to produce a built it "spider" to interface the two parts
All being well my nephew is producing a 9 cylinder 3D printed dummy engine
Last edit: 07 Jun 2024 19:05 by kevinross.
11 Jun 2024 16:31 #26826 by Phil Ford
Certainly been a major project Kevin, surprised you have stuck at it.   There are full  kits and there are kits and make the rest up as you go along.  No wonder ARFs are popular!
22 Jul 2024 20:17 #26863 by kevinross
Having previously moulded the outer shells for the spats, i need an inner pair with flats to assist mounting to the U/C leg adapters.
I poured an equal volume of epoxy & micro balloons into each mould then layered the inner sections
After trimming the edges i fixed small balsa teeth alternatly to aid alignment. They are now fixed with cyan to enable me to join with glass bandage
28 Aug 2024 09:16 #26869 by kevinross
after a 4 weeks break to complete another ARTF  - started trial fit and blending of the Spats and Engine cowl
Time to create page: 0.312 seconds
