  • Phil-C
19 Oct 2015 10:40 - 19 Oct 2015 10:41 #6608 by Phil-C
I'm in. The Blue Angel flies as though it's on rails.
If the Atlas lives up to it, we will have a fleet of pattern ships, designed to be fault free.
Anyone else in?
Last edit: 19 Oct 2015 10:41 by Phil-C.
20 Oct 2015 09:45 - 20 Oct 2015 10:11 #6620 by Chris001
I hope the Atlas doesn't disappoint Phil, The Blue Angel really was wonderful to fly even if I was shaking when I handed it back to Mike, I really didn't want to do anything to endanger his plane. But, if the Atlas flies like that I'll be really happy. Glad you're on board.
Last edit: 20 Oct 2015 10:11 by Unnamed user.
20 Oct 2015 13:39 #6621 by JonTappin
I am certain the Atlas will fly every bit as well as the Blue Angel, Wolfgang knew what he was doing!
Not sure it is going to be much, if any, slower than the BA though as per an earlier post. Is this assumption down to the straight wing vs swept or something else,eg wing section thickness?
20 Oct 2015 13:48 #6622 by JRI
Phil-C wrote: I'm in. The Blue Angel flies as though it's on rails.
Anyone else in?
Not on the build - but I would certainly enjoy seeing more proponents of pattern flying in the club. Its a rewarding discipline which takes an enormous amount of effort and practice to achieve even basic aerobatic maneuvers in the right place and of the right shape and size.
  • Unnamed user
20 Oct 2015 17:07 #6623 by Unnamed user
Replied by Unnamed user on topic Winter build project: Wolfgang Matt’s ATLAS
JonTappin wrote: Not sure it is going to be much, if any, slower than the BA though as per an earlier post. Is this assumption down to the straight wing vs swept or something else,eg wing section thickness?
This is in reference to a quote from Wolfgang Matt back in 1976:
Q: You seem to prefer a straight taper configuration. Any reason for this?
A: I tried swept wings, but this design needs more speed which requires a faster flying style. I do not like a fast flying style that much
I'm not wholly convinced by this argument but this is what he thought 40-years ago.
However, the Atlas does (I think) have a thicker aerofoil. I think I read 22% somewhere, although this does seem a little too much. The BA is a more typical 18% section. This might have an effect on the speed?
20 Oct 2015 17:10 - 20 Oct 2015 17:35 #6624 by Chris001
Mike beat me to it as I managed to write my post and then somehow lost it!
Mike, thanks for editing my last post, was I incoherent, inadvertently rude to Phil, or did I call your Blue Angel and Blue Angle again... or was it some other misdemeanor . :)
I know a google search would probably answer my question, but what does 22% aerofoil mean, 22% of what? Is there an idiots guide to wing shapes and aerofoils that anyone can point me in the direction of.
Last edit: 20 Oct 2015 17:35 by Chris001.
  • Unnamed user
20 Oct 2015 17:53 #6626 by Unnamed user
I edited because you had missed the word 'on' in the last sentence.
22% refers to how thick it is compared to its length. Since you have the plan, can you measure the length of the wing root section and the maximum thickness. Then do thickness divided by length x100 to find the percentage thickness.
As for an idiots guide, do a google search on NACA and Eppler for some insight.
  • Unnamed user
20 Oct 2015 17:55 #6627 by Unnamed user
...and Martin Hepperle has loads of info on his website
www.mh-aerotools.de/airfoils/index.htm
20 Oct 2015 20:43 - 20 Oct 2015 20:44 #6628 by JonTappin
I read that as a swept wing needs to fly faster, rather than it will be faster.
However a thicker wing section will slow it down and should also lower the stall speed, although wing loading will also be a factor.
We shall see!
Last edit: 20 Oct 2015 20:44 by JonTappin.
20 Oct 2015 22:55 #6629 by Chris001
MikeSeale wrote: ...Since you have the plan, can you measure the length of the wing root section and the maximum thickness. Then do thickness divided by length x100 to find the percentage thickness.
Length: 337mm
Maximum thickness:63mm
Percentage thickness: 18.7%
So that would make it similar to the Blue Angel?
Time to create page: 0.370 seconds
