28 Oct 2015 20:46 #6754 by MikeSeale
Triangular stock on the formers is not necessary but you can add it if you want. It's useful for the under-wing fairing as an infill so that you can carve/sand to the correct section without reaching fresh air. Also at the nose where you need to sand down to the spinner disk.
05 Nov 2015 12:14 #6850 by John Bannister
Could anyone with a paper plan measure the length of the fuselage from tip of spinner to rear of rudder and tip of wing to center line, I need to check my plan.
Thankyou John
05 Nov 2015 12:44 #6851 by Chris001
Hi John,
Fuselage from tip of spinner to rear of rudder on '0' line is 140cm
Tip of wing to center line is 83cm
Do I take it you are going to put an Atlas together?
05 Nov 2015 19:32 #6864 by John Bannister
I will make a few bits and see how it goes
05 Nov 2015 20:58 #6866 by flyingpete
Blimey! Is someone actually going to start building one of these badboy's :woohoo:
05 Nov 2015 21:26 - 05 Nov 2015 21:45 #6867 by Chris001
Blimey Pete, give us a chance, my wood order went in last night, if Mike ever tells you it'll only cost £50 then add at least half again :woohoo:
Anyway, I had hoped the wood would arrive before the weekend, it looking a tad wet and windy, but alas it'll won't be shipped until Monday.
In the mean time I've been deciding how best to test the wood so that I can be confident that it meets my demanding requirements. For example we all know resonance can be very dangerous as it can shake a plane apart, so I've decided to measure the natural resonance of all the wood and ensure that I don't put harmonically similar wood next to each other, for example this piece of wood resonates to the note A when wacked:
The other thing I need to consider is the impact resistance of the wood, the size of hammer and velocity which it was swung were all scientifically calculated to simulate one of my landings. :whistle:
Please note the above image is for Simon, who berated me at the weekend for a lack of balsa bashing :evil:
Please also note, no balsa was harmed the creation of these photos.
Last edit: 05 Nov 2015 21:45 by Chris001.
05 Nov 2015 21:47 #6868 by AlanF
That's dedicated work Chris. Are you going to fit a truss rod to adjust the wing incidence?
05 Nov 2015 22:19 #6869 by DaveBright
Chris....all this about notes and harmonic resonance? Does that mean that (God forbid it ever went in) would the sound be less or more pleasant?
05 Nov 2015 23:19 #6870 by Chris001
Mr Bright, how could you even contemplate such a thing, I'm shocked ;)
However I suspect it might sound a bit like this... imagine an electric guitar with a lot of distortion, now scrape the edge of the pick down the bass e string towards the nut before strumming a big fat E minor chord, and if you happen to be playing Alan's Strat, give the whammy bar a good slow wobble at the end. :pinch:
Alan, I'm contemplate the biflex tussrod and micro tilt adjustment ;)
On a serious note, when joining the extra lenght onto the fuselage side, I'm assuming the join is reinforced with the ply doubler, but is it also wise to do a scarf joint?
05 Nov 2015 23:25 #6871 by MikeSeale
It won't hurt to do a scarf joint, but the Blue Angel plan just has a butt joint and the ply holds it together. I'll do the same on the Atlas.
Time to create page: 0.401 seconds
