WMAC Group build - Impressivo
23 Jan 2014 17:32 #1138 by DavidTappin
Please don't pick on my little friend, that's my job.
Given me ideas though, I've just got home from Spire Models having bought some nice dayglow orange Profilm
David
PS Watch out for the next issue of the BMFA News, due on your doorstep on Feb 12th.
  • Phil-C
23 Jan 2014 18:39 - 23 Jan 2014 18:39 #1139 by Phil-C
Solution to the hand launch damage potential:
Make it a tractor :S
I also had to put a hatch over the ESC, or it weren't goin' in
Last edit: 23 Jan 2014 18:39 by Phil-C.
30 Jan 2014 18:06 #1157 by simondean
After my last question met with no response I'll try again with a different one. Am I right to assume the best method of securing the servos is to glue them to the ply support ?? If so what's the best glue to use ?
30 Jan 2014 18:26 #1158 by DavidTappin
Simon originally asked
How's others getting on ?
- and nobody replied, shame on us. Sorry Simon. I'm now on the last lap, in the process of applying Profilm, can't speak for everyone else. As for securing the servos, I used epoxy, wasn't too confident about using cyano, "frozen" servos are a useless waste of money.
30 Jan 2014 18:37 #1159 by simondean
Thanks David for your rapid response !
30 Jan 2014 18:44 #1160 by JonTappin
Sorry for letting you down Simon, I couldn't offer any advice based on my experience as mine is still in it's box :(
I'm doing better than Dave B though, he hasn't even collected his from me yet :)
30 Jan 2014 18:59 #1161 by kevinross
simondean wrote: After my last question met with no response I'll try again with a different one. Am I right to assume the best method of securing the servos is to glue them to the ply support ?? If so what's the best glue to use ?
This is not the best photo to show how i have secured the servos.
For each servo lug (4 off) I have made stacked up 3 squares of 3mm light ply to make a block about 15mm x 15mm x 9mm. Then cut a slot to locate the servo lug and glued the blocks to the ply servo plate.
You may also note that i have re worked the servo lead cut outs in order to keep the plugs inside the fuselage.
30 Jan 2014 20:59 #1162 by MikeSeale
kevinross wrote: For each servo lug (4 off) I have made stacked up 3 squares of 3mm light ply to make a block about 15mm x 15mm x 9mm. Then cut a slot to locate the servo lug and glued the blocks to the ply servo plate.
I'm possibly being a bit thick, but I can't understand what you've done here. Any chance of a clearer description for the hard of thinking?
30 Jan 2014 21:04 #1163 by MikeSeale
Re. servos...I always rought up the surface with a very coarse permagrit block to give the epoxy something to key onto. Only use a small blob of epoxy...it squeezed out and will need a lot of mopping up otherwise.
30 Jan 2014 21:11 #1164 by kevinross
Hope this is clearer
Time to create page: 0.382 seconds
