WMAC Group build - Impressivo
01 Feb 2014 13:19 #1176 by DavidTappin
PhilC wrote
"then a blob of hotmelt going through the lug holes"
Likely to cause hearing loss?
01 Feb 2014 13:54 #1177 by MikeSeale
JonTappin wrote: I found a picture of this launching device online, what do you think?
I use a similar devise to this, Jon, but mine has the thumb on the other side.
  • Stuartmck
01 Feb 2014 16:59 #1178 by Stuartmck
Looks quite handy!
Stuart
  • Phil-C
01 Feb 2014 17:33 #1179 by Phil-C
David, couldn't quite hear you. :dry:
Is there not one of those launching devices hanging up in the hut? :sick:
My weight is now 410 gram for the complete airframe and 380 gram for the hardware, 790 gram in total. :unsure:
01 Feb 2014 23:17 #1180 by DavidTappin
Phil, unless your airframe weight includes the two servos its a bit porky. Mine is 380 grams including the servos.
But the rest of my hardware is heavier than yours, what battery are you using? Mine is only a 30C 2100 3S-1P Kokam but it weighs 210 gram.
Perhaps, just like me, it put on weight over Christmas.
The following user(s) said Thank You: Phil-C
  • Phil-C
02 Feb 2014 09:50 - 02 Feb 2014 09:58 #1181 by Phil-C
410 includes servos, ailerons, fins horns. H/W is 2200 LiPo, motor, controller, prop collett, reciever, all plugs and sockets soldered. Bat weighs 185 gram. Overlander 30 C.
Last edit: 02 Feb 2014 09:58 by Phil-C.
02 Feb 2014 11:28 #1182 by Dante
Replied by Dante on topic WMAC Group build - Impressivo
All this talk of fat batteries, feed them less calories, try Kellogg's Special K. :whistle:
04 Feb 2014 09:47 #1183 by 4Pedalsfly
Replied by 4Pedalsfly on topic WMAC Group build - Impressivo
Mike - I've used the masking tape method on a number of models with no problems.
The servo usually goes either into a balsa box or cut out in a foam cored wing, the servo
is a tight fit and once the glue sets it will not move.
I used this method on a 2.7 m scale glider for fixing the flap & aileron servos into a foam cored wing
and four years later they are still firmly attached.
Colin.A
05 Feb 2014 15:37 #1185 by DaveBright
Kit acquired.....
  • HIGHBANK2
05 Feb 2014 18:00 - 05 Feb 2014 18:10 #1192 by HIGHBANK2
Replied by HIGHBANK2 on topic WMAC Group build - Impressivo
Hi Guys
A review of my other modelling projects, and acknowledgement of some health issues I need to address, means that I have not started my Impressivo kit.
I am therefore putting it up for sale at £55 – so if you have a colleague/friend who wants to join in the project get him/her to ring me on 01202-880847 or contact me via dsashenden@aol.com.
Regards to all
Dave Ashenden
Last edit: 05 Feb 2014 18:10 by HIGHBANK2.
Time to create page: 0.480 seconds
