WMAC Group build - Impressivo
10 Feb 2014 23:10 #1254 by DavidTappin
PhilC wrote
though they looked like Aly to me
Sorry, forgot to mention, using brass tube for mine, you're right, aluminium tube was supplied in the kit!
  • tommy
11 Feb 2014 09:20 #1255 by tommy
Replied by tommy on topic WMAC Group build - Impressivo
I must commend those currently building the impressivos at the moment, some great pictures am looking forward to the maiden day.
Not sure if anyone is interested but I noted there was talk of launching systems the other week on the thread. Hobbyking sell a Pedal Operated Bungee Launch System priced at £15.75 and it's in the UK. It appears to include all the necessary parts required and has good reviews. Would love to upload pics but got into all sorts of trouble trying last time around trying to re-size pictures and what not so thought I would just give the info this time.
Am going to get one myself as building an EDF viper jet at present but wont be finished for some time so wont be testing the launch system for a while.
I must admit, I havn't checked whether the club object to a contraption like this but wouldn't have thought so as long as it's positioned at the edge of the field. Can someone let me know ?
Tom
  • Phil-C
11 Feb 2014 10:02 #1256 by Phil-C
David, I was all set to use some brass ferules because I had put the two aly things somewhere safe. Then I remembered where I had put them, so they are on, and seem to be well stuck. I guess filling them with solder then pushing them on with a hot iron has worked by mechanical means rather than chemical bonding. Might lightly crimp as well.
11 Feb 2014 10:08 #1257 by Phil Ford
Phil-C wrote: And it's not the workshop, David. I was allowed indoors 'cause it were cold.
Aren't you the lucky one! :whistle: I had to wrap up warm in the garage after glueing the bread board to the worktop. If this weather don't break soon I'll run out of models to build / maintain........... :(
  • Phil-C
12 Feb 2014 19:33 #1262 by Phil-C
I am a LiPo virgin. I can charge them up OK. I have read that you should have a voltage regulator between the ESC and the receiver, or "Emphang" as we now call it. Don't know how old the advice was.
Is this necessary/good idea/not necessary ??? :dry:
Are ESCs now good enough to provide a regulated 4.8 volts? Without a programming card or any instructions whatever from HobbyKing, how do I set it??
12 Feb 2014 20:07 #1263 by MikeSeale
If you are using the speed controller that I recommended you can just 'plug and play'. No need for any regulator...the ESC will provide (probably) 5.2V to the receiver.
12 Feb 2014 20:15 #1264 by MikeSeale
Here is the instruction manual for the YEP 60 ESC
  • Phil-C
13 Feb 2014 12:29 #1265 by Phil-C
Thanks for the manual, Mike.
  • Stuartmck
13 Feb 2014 15:14 #1266 by Stuartmck
Phil
Just for info, a regulator was required when using a LiPo as a Rx battery, in place of NiCd or NiMh 4.8/6.0V
Stuart
13 Feb 2014 19:12 #1268 by MikeSeale
I also wonder, Stuart, if the info refers to using a speed controller with a linear BEC? Nowadays, nearly all ESC's have switching BECs and can be run safely on 3s-6s lipo. In the old days, you had to disable the BEC and use a separate SBEC.
Either way, it's much simpler now.
Time to create page: 0.482 seconds
