WMAC Group build - Impressivo
  • Phil-C
09 Feb 2014 12:33 #1233 by Phil-C
Just finished linkages and hatch catches. Install hardware and apply decals and I'm ready. Might put a tow hook in.
09 Feb 2014 12:40 #1234 by DavidTappin
Lovely tidy workshop Phil, and the apples look delicious.
09 Feb 2014 12:55 #1235 by kevinross
DaveBright wrote: balls, dark colour it is!
Never mind the colour Dave - Just concentrate and make sure you don't glue it with coffee then drink the Cyno !!
  • Phil-C
09 Feb 2014 16:39 - 09 Feb 2014 16:39 #1243 by Phil-C
Any tips on how to fix the tiny ferules on the 0.8 mm wire linkages?? If I cyano them, will they come off if I try hard enough? :S
And it's not the workshop, David. I was allowed indoors 'cause it were cold.
Last edit: 09 Feb 2014 16:39 by Phil-C.
09 Feb 2014 17:11 #1244 by DavidTappin
Phil C asked
Soldering will do nicely Phil. Don't worry about the G/F horns, just like committee members they can take the heat. So make sure that the z bend is at the servo arm end!
David
09 Feb 2014 18:02 #1246 by MikeSeale
I'm not at that stage yet, but you could also try a crimp prior to soldering for 'belt and braces' approach. However, I'll probably put a z-bend both ends. Get it all lined up before gluing the horn onto the control surface.
09 Feb 2014 18:04 #1247 by kevinross
I simply made the first 90 deg bend with pliers then the second of each Z bend by hand. after installation of horn and servo. (Z bend pliers make too large / wide bend causing excess slop)
  • Phil-C
10 Feb 2014 13:48 #1251 by Phil-C
I did my Z bends with fine nosed pliers, then, made keepers out of a bit of plastic.
Soldering the other end seems to have worked, though they looked like Aly to me.
10 Feb 2014 20:04 #1252 by simondean
Finished the covering, got to install the gear and motor, fix the wings and set up control throws. So about another months work !!
10 Feb 2014 20:29 #1253 by JonTappin
Come on Simon, pictures please :)
Time to create page: 0.365 seconds
