WMAC Group build - Impressivo
11 years 4 months ago #1301 by MikeSeale
The only other 'clever' thing I did was with my antenna. How do you keep them at 90 degrees to each other after stuffing the receiver down the nose? Simple...cut a triangle of plastic and tape the ends in place. It doesn't matter if they rattle around a little, they will always be at 90 degrees to each other.
[IMG
11 years 4 months ago #1302 by DavidTappin
Very smart Mike. Good thing you're not coming to the skittles, that one looks like a winner!
11 years 4 months ago #1305 by DaveBright
Now the tricky bit!
11 years 4 months ago #1307 by DavidTappin
Coming on then Dave. I see you managed to nearly sand off the magic marker writing. Keep up the good work.
But will it be ready for the judging of the best Impressivo at the skittle night? Come to that will you be ready for the skittle night, I haven't seen your menu choices yet.
David
11 years 4 months ago #1308 by DaveBright
Yes, I've nearly rectified my schoolboy error! I won't admit to the additional ones I've made through the assembly.
It may be ready for the 27th.... And I shall get our menu choices through to you asap!
11 years 4 months ago - 11 years 4 months ago #1309 by
Like the colour scheme, Mike. I also like the battery holder, which I have copied. The plate for my tow hook makes a good base to screw it to.
Here is a sketch of the hook arrangement. I had a hint or two from Mike. All stuck with laminating resin. The photos kind of show it as well. It had to be inserted in three pieces in order to thread the hook up from underneath. The locator pegs make sure it fits together.
Apart from that, finished.
Phil
Last edit: 11 years 4 months ago by .
Time to create page: 0.437 seconds
