Stearman build
20 Jan 2021 14:34 - 20 Jan 2021 14:35 #24072 by Phil Ford
Starting to resemble something that eventually will fly. B) Nice work Kevin. By the time you have got to wing 4 you'll be thinking "Why did I not do it this way earlier!" Myself I have said this many times with multiple items that had to be made up identical. :lol:
Last edit: 20 Jan 2021 14:35 by Phil Ford.
31 Jan 2021 13:00 #24136 by kevinross
For the first wing L/E sheeting i just formed it around the bathroom towel rail but had some difficulty fixing. Subsequently shaped them on a tighter radius allowing them to fit like a glove dry. Now they can be fixed without pins.
Definitely getting the hang of this old building lark !
06 Feb 2021 17:56 #24169 by kevinross
wing No 4 nearing completion. I had to rework the upper wings to introduce ailerons riblets while retaining the wing shape then cut out the skeleton structure.
06 Feb 2021 18:01 #24170 by kevinross
I glued the aileron L/E ply wrap to a sub spar - then steamed these to preform it. Masking tape used to hold the ply around the front then clamped to ensure a good bond to the upper sub spar.
12 Jan 2022 22:06 #25467 by kevinross
Its build time again and phase 3 of my Stearman build. With all the major components completed by last April its time to blend the joins and rig the parts .
The winter storms finished off my 10yrs old patio umbrella but i saved the alloy ribs which have come in useful to make setting bars to rig the wings in conjunction with a string line to align the wing spars.
The plans just call for bonding these wing root tie bars to the first ribs but ive fitted some light ply plates to increase the bonding area and used small screws to set the wings fore / aft angle
03 Feb 2022 21:05 #25531 by kevinross
Many of you know about my love hate relationship with Saito gas engines so in the end I divorced the FG60-3 and sourced a new partner.
This is a Valach 70cc and reputed to be one of finest R/C motors and produced in Czech which i'm currently shoehorning into the Stearman.
04 Feb 2022 08:52 #25533 by JRI
Does the exhaust fit inside the cowl?
04 Feb 2022 09:55 - 04 Feb 2022 09:58 #25534 by kevinross
No the exhaust fits in the Fuselage - obviously i'll need to box it in and protect file tank and servos. see this example from Toni Clarke models. In this installation you can see the exposed fuel tank above the exhaust. Like my model. the cockpits are open so there is plenty of air flow. The beauty of this exhaust system is it has no baffles so can be installed either way
Last edit: 04 Feb 2022 09:58 by kevinross.
04 Mar 2022 13:26 #25659 by kevinross
Initially the exhaust kits were not available so thought i could just make one out of wood. :silly: (in order to do the fuselage prep)
Now the kit has arrived. The super lightweight can is made by Zimmerman.
04 Mar 2022 13:29 #25660 by kevinross
The header is now complete and ive fabricated a clamp for the exhaust can from S Steel strip
Time to create page: 0.395 seconds
