Stearman build
17 Feb 2023 09:54 #26431 by kevinross
The mounting plates were fabricated by cross drilling at the 25deg
The sleeves were set at 25 deg by supergluing a couple of 15mm gland nuts on a fire clay baked up with sone tile cement.
17 Feb 2023 18:13 #26434 by JRI
Please explain cross-drilling. If I tried to get that angle the drill would wander (or did you glue it to a wooden block and drill through the block)?
17 Feb 2023 20:21 #26435 by 4Pedalsfly
Replied by 4Pedalsfly on topic Stearman build
Hi John - Slot in wooden block is at 25 degrees into which plates are are a tight fit.
Drill guide hole in block at 90 degrees - plate held captive so drill cannot wander.
Yorkshire Tea is essential for such projects. !!
Colin.A
17 Feb 2023 22:02 #26436 by kevinross
I have many tools and machines but not one of everything so have to adapt tasks to the tools i do have.
Drilled thru the wood block and plates with a 4mm drill followed by a 6mm as a prerequisite to boring thru with the my most suitable end mill (14mm) in the milling machine. (because end mills cant bore within  their centres)
Finally i opened the bore to match the 15mm tube using and expanding reamer
18 Feb 2023 07:56 #26437 by kevinross
Colin.A
HAR DID THA KNOW THAT !
18 Feb 2023 18:23 #26439 by kevinross
Now complete -shown fitted to a demo spat, adding 20g per side. The addition boss will add substantial extra rigidity to the axle.
25 Mar 2023 22:45 #26462 by kevinross
Have now finalised all the dimensions for the Cabane, Interplane struts and rigging wires with temporary fixings which will be made with a mixture of metal and carbon, then sleeved with K & S alloy streamlined tube.
25 Mar 2023 22:53 #26463 by kevinross
These are the K & S tubes for the interplane struts which will be reinforced with carbon tube
Ive made my own lightweight thread / carbon adapters using these aluminium alloy bolts which have been knurled to give better adhesion in the carbon tube
Then ive removed the pins from some 3mm clevis to provide the connection
11 Feb 2024 16:30 #26727 by kevinross
More progress on the fwd fuselage attaching the 0.8mm plywood skins - Amazing how versatile this material is with a lot of water and heat.
11 Feb 2024 16:31 #26728 by kevinross
more plywood prep work
Time to create page: 0.426 seconds
