Stearman build
04 Mar 2022 13:37 #25661 by JonTappin
Replied by JonTappin on topic Stearman build
Should sound lovely on that Zim can Kevin!
What are you doing for an air outlet for the can cooling?
04 Mar 2022 14:37 - 04 Mar 2022 16:16 #25662 by kevinross
Ive built a balsa box to reduce heat transfer to to fuel tank and will make 'suitable outlet holes into the Fuselage aft of the tank.
Stearmans are open cockpit so there should be plenty of exit area.
Updated - see balsa box for can and planned cooling
One bright side of being outside the EU is if the shop is set up to export to us they dont charge German VAT - a real blow. If you keep the invoice < £135 keeps you below the UK import duty threshold. The exhaust kit was sipped Thursday and arrived Tuesday.
Last edit: 04 Mar 2022 16:16 by kevinross.
15 Mar 2022 11:42 #25715 by kevinross
When commencing this project, i was determined to make the field assembly easy which seemed easy in theory but putting my ideas into practice has stretched me somewhat. I also wanted to avoid having 12 chunky and unrealistic clevis to constantly adjust.
My solution was to create intersecting boxes in the wing structure. One box to accept the interplane strut and a second to accept a fitting which combines the paired flying wires and secures everything with a single screw. The wires are cosmetic only so will be tensioned by springs in the fuselage & upper centre section. The fittings are fabricated from stainless strip & half round brass block silver soldered in place. Then m2 bolts & commercial brass spacers.
  • Brian Jackson
15 Mar 2022 14:54 #25716 by Brian Jackson
Replied by Brian Jackson on topic Stearman build
Nice work Kevin, looking forward to seeing the model at Cashmoor.
30 Mar 2022 13:20 - 30 Mar 2022 13:43 #25739 by kevinross
Some of you may remember when i started this project 2 yrs ago I chose to base it on NC 9039H because I just fell in love with the red / silver colour scheme. I knew the full size had undergone a massive restoration and thought it had been retired to a specialist museum in California.
However, Ive recently discovered the aircraft was used for filming some improbable or impossible mission at Duxford last Nov by some guy called Tom Cruise whoever he might be. Personally i think a beautiful aircraft has been ruined.
Last edit: 30 Mar 2022 13:43 by kevinross.
30 Mar 2022 17:41 - 31 Mar 2022 09:50 #25741 by Phil Ford
Who the hell is Tom Cruise? :lol: His last foray into aircraft stunts, ie;Top Gun film we lost another famous aerobatic pilot - Art Sholl
Last edit: 31 Mar 2022 09:50 by Phil Ford.
30 Mar 2022 22:18 #25742 by kevinross
Upper wing and centre section now complete but the T/E balsa was a bit soft and has suffered some hanger rash so i've reinforced these with 1.5 mm hardwood. Ready to cover.
The following user(s) said Thank You: Phil Ford, Brian Jackson
31 Mar 2022 22:27 #25749 by 4Pedalsfly
Replied by 4Pedalsfly on topic Stearman build
Kevin - Looking very impressive now - seems a pity to cover up all that structure, what covering
material have you decided on ?
31 Mar 2022 22:38 - 31 Mar 2022 23:26 #25751 by kevinross
The jury is still out with options of Oratex or a newer product Diatex used extensively by professional model builders "Fighteraces"
Brian recently posted about the product.
Last edit: 31 Mar 2022 23:26 by kevinross.
31 Mar 2022 23:35 #25752 by kevinross
the upper and lower aileron profiles and pivot points are not equal so this mock up seemed preferable to my mathematics ability to determine the ideal pivot points for the aileron interconnecting rod. The critical objective being to avoid introducing adverse aileron differential.
The following user(s) said Thank You: 4Pedalsfly, Brian Jackson
Time to create page: 0.392 seconds
