Stearman build
07 Nov 2022 08:59 #26311 by ruggerbloke
Replied by ruggerbloke on topic Stearman build
Top quality work there Kevin. Well done.
07 Nov 2022 09:09 #26312 by kevinross
4 more cycles and nearly there - I discovered a high tech solution to separate the two halves during the process - its called sellotape !!
07 Nov 2022 09:12 #26313 by kevinross
This semi rigid plastic sheet will provide the separator when i produce the mould
08 Nov 2022 21:10 #26320 by kevinross
Fwd and rear plugs now mounted for laminating moulds but that stage may have to wait for fine weather. In the meantime i need to make a half plug to produce 4 half wheel pant sections
09 Dec 2022 10:40 #26363 by kevinross
My first attempt to make the wheel spat plug was OK but once again John Banister provided his excellent skills with CNC design and manufacture and produced two perfectly matching back to back plugs.
09 Dec 2022 10:48 - 09 Dec 2022 10:52 #26364 by kevinross
In the end I concluded it would be easier for me to slice the block in two using my bandsaw and mount for final shaping/ smoothing.
The plastic separator will prevent any filler gluing the two halves together
Last edit: 09 Dec 2022 10:52 by kevinross.
17 Dec 2022 09:26 #26371 by kevinross
Spread over the last week the plugs have required about 10 cycles of cut back / fill / cut back / etc to get to this stage. Now taken them to my local car body shop who will apply 2 -pack primer filler (they'll use up the surplus in spray gun when doing repairs)
17 Dec 2022 12:05 #26372 by DavidTappin
Replied by DavidTappin on topic Stearman build
More power to your elbow Kevin!
26 Dec 2022 19:41 #26381 by kevinross
Picked up the plugs from the body shop last week after a few heavy coats of 2 pack primer. Now cut back, polished and ready for using to make the molds.
17 Feb 2023 09:51 #26430 by kevinross
The basic kit design has no provision to secure wheel spats so have made these adapters ( some reshaping and lightening still to do) - Commercial products would not secure the spats in the correct position
Time to create page: 0.411 seconds
