Mk 11C Hurricane winter build
13 Dec 2014 10:57 - 13 Dec 2014 11:31 #3352 by flyingpete
Replied by flyingpete on topic Mk 1 Hurricane winter build
The fus keel and spine were made up and glued to former 4 and the lower formers glued,tail plane supports also added.
A center datum line was drawn on the building board,the formers were marked with a center line and then fus pinned down over the center line.The stern post was jigged up to keep it plumb.This is the most critical part of the fus build as there are a total of 50 stringers to be added and it would be very easy to build in mistakes.
I numbered each former 1-25 each side and started to cut and fit the stringers in pairs starting from the top and glued in place with med cyano and kicker as i wanted an instant bond ,checking all the time that every thing was nice and straight and plumb.Once all the stringers were in i gave the fus a tidy up with the razor plane and a quick sand down.
Will post up pic's shortly
Pete B)
Last edit: 13 Dec 2014 11:31 by flyingpete. Reason: text added
13 Dec 2014 17:17 - 13 Dec 2014 17:35 #3355 by flyingpete
Pictures:
Last edit: 13 Dec 2014 17:35 by flyingpete. Reason: no pics
13 Dec 2014 18:26 - 13 Dec 2014 18:29 #3356 by flyingpete
Ok then chap's onto the tail plane.This is built upside down so to give slight dihedral also the hurricane had a fabric covered tail plane so after it had been sheeted you will see i have added 1/16 capping pieces to give the impression of an open structure
Attachment DSC_0074.jpg not found
Attachment DSC_0075.jpg not found
Attachment DSC_0078.jpg not found
Last edit: 13 Dec 2014 18:29 by flyingpete. Reason: add pic
13 Dec 2014 18:31 #3357 by flyingpete
I need to have a tidy up
Attachment DSC_0093.jpg not found
13 Dec 2014 18:38 #3358 by flyingpete
Elevators next,very simple construction 3/16 core with riblets glued top and bottom 3/8 leading edge and soft 1/2 for the tips.Carve to shape with balsa plane and then a good sand job done add trim tab detail
Attachment DSC_0079.jpg not found
Attachment DSC_0080.jpg not found
13 Dec 2014 18:47 #3359 by flyingpete
Trial fit of the tailplane and fin
Attachment DSC_0088.jpg not found
General pics
Attachment DSC_0083.jpg not found
Attachment DSC_0084.jpg not found
13 Dec 2014 18:51 #3361 by flyingpete
More pics
Attachment DSC_0085.jpg not found
Attachment DSC_0086.jpg not found
Attachment DSC_0087.jpg not found
Attachment DSC_0090.jpg not found
13 Dec 2014 19:06 #3362 by flyingpete
So after just over 100 hours that is where the hurri stands at the moment.Not much going to happen till after xmas as i have bought my grandson his first hornby train set and will be making a layout for it to go on .
Stay tuned
Pete B)
13 Dec 2014 20:45 #3363 by Chris73
Replied by Chris73 on topic Mk 1 Hurricane winter build
Looking good Pete, would have taken me years to get that far :whistle:
13 Dec 2014 22:46 #3364 by DaveBright
Replied by DaveBright on topic Mk 1 Hurricane winter build
Great stuff Pete. Watching on in anticipation.....
Time to create page: 0.447 seconds
