Mk 11C Hurricane winter build
28 Dec 2014 19:39 #3444 by flyingpete
Replied by flyingpete on topic Mk 11C Hurricane winter build
Ok chap's,hope you had a good christmas B) Right hand outer wing panel uderway
28 Dec 2014 20:11 - 28 Dec 2014 20:24 #3445 by flyingpete
Right hand panel glued to centre section.In the second picture you will see that i have left a 3/32 gap between the 2 ply ribs in the middle section of the wing tube on the right hand panel so after sheeting the top surface it will act as a guide for a hack saw blade to cut through the wing joiner and spars to make a 3 piece wing after doing the same with the left hand outer panel.You could i suppose sheet the wing in 3 separate panels but doing it the way i have, will make sure everything stays inline,the last thing you need is a badly fitting wing joint on the wing tubes.
Last edit: 28 Dec 2014 20:24 by flyingpete.
01 Jan 2015 20:05 #3462 by flyingpete
A bit more done
04 Jan 2015 12:36 #3470 by flyingpete
Wheel wells cut out and outer flaps underway
05 Jan 2015 19:37 - 05 Jan 2015 20:09 #3484 by flyingpete
Well the airframe is complete B) next step is to put it all together for the first time,check all is okay give it a good fill and rub down and a coat of clearcoat at to the airframe and think about getting some text ironed on woooohoooo
Last edit: 05 Jan 2015 20:09 by flyingpete. Reason: text
05 Jan 2015 20:07 #3485 by DaveBright
Replied by DaveBright on topic Mk 11C Hurricane winter build
Nice one Pete
05 Jan 2015 20:45 #3486 by flyingpete
Thanks Dave
06 Jan 2015 18:12 #3487 by JonTappin
Replied by JonTappin on topic Mk 11C Hurricane winter build
Looks like you're really cracking on Pete. I love that 'ready to cover' stage of a build :)
Keep the photos coming!
06 Jan 2015 18:51 #3488 by flyingpete
Jon
It was always my intention to get the airframe ready to cover early 2015 so hopefully it will be ready to paint early spring.I'v missed a few good flying day's stuck in the workshop but i am sure it will be worth it.I was hoping to get her in the garden this week to give it a good rub down and take some pics but looks like the weather is not playing ball :( Still need to pluck up courage and part with £850 for the bespoke retracts :ohmy: shame a set of E-flight will not fit LOL
06 Jan 2015 23:39 - 06 Jan 2015 23:44 #3490 by DavidTappin
Replied by DavidTappin on topic Mk 11C Hurricane winter build
Deleted
Last edit: 06 Jan 2015 23:44 by DavidTappin. Reason: I was going to make a funny remark about taking her out in the garde for a good rub down but thought better of it
Time to create page: 0.372 seconds
