27 Feb 2016 19:04 #8127 by JonTappin
The Biplane is his Citrin probably from around 2010 or 11, still flying competitively now so more modern than the Miss Wind
I think the first f3a biplane was around early 90's
03 Mar 2016 22:44 #8182 by DavidTappin
Replied by DavidTappin on topic Winter build project: Wolfgang Matt’s ATLAS
I'll rightly be accused getting off the subject but this topic has illustrated an encouraging resurgence of interest in woodwork and I couldn't resist sticking in this illustration of fine craftsmanship in wood and dedication to a challenging subject so there is a little synergy here:
There must be an easier way to loose your marbles!
03 Mar 2016 23:13 - 03 Mar 2016 23:13 #8183 by Chris001
There is not much more I can say other than... Wow.
Blimey, just to come up with the idea and then to work out how all the timings and interactions are going to work is just wonderful. Thanks for finding it and posting David, I remember being mesmerised by my dad's ball bearing clock when I was a kid, this is on a whole new level.
Last edit: 03 Mar 2016 23:13 by Chris001.
19 Mar 2016 10:28 - 19 Mar 2016 10:28 #8302 by Chris001
There's not been anything new on this thread for a while, so I thought I'd see any anyone can see any flaws in my thinking with regards the correct axle positioning of the main wheels
I'd originally established my ground level and mocked up the retract on the plan to get my measurements:
But this morning it occurred to me that the wing has dihedral and is tapered from root to tip, so any measurement at the root of the wing as I have been doing on the plan is inaccurate.
When Mike kindly sorted out the foam cores for the wings, he built in both the wing taper and the dihedral, so I've measured the bottom half of the foam core waste at the retract position and at the root.
The difference being 11mm (94mm & 105mm) and plan to add that to my original measurement I took at the root down to my ground level (minus half the wheel diameter)
Does this all sound about right?
Last edit: 19 Mar 2016 10:28 by Chris001.
19 Mar 2016 10:44 #8303 by MikeSeale
That all sounds fine...the bottom of the wing does have a lot of dihedral in order to accommodate the 8mm on the top. However, I did not take this into account and ended up ok.
19 Mar 2016 10:51 #8304 by Chris001
You wanted a positive angle of attach anyway, you might have just got a little more than you planed for. Does the Blue Angel have 0º angle of attack or negative, I'm assuming it was the sticking to the ground nature of the Blue Angel that made you purposely build in a positive angle of attack for the Atlas. All the similar MK plans seem to indicate the undercarriage is set to give 0º wing incidence to ground level.
19 Mar 2016 11:53 #8305 by MikeSeale
TBH, the Atlas appears to sit a little more nose down than the Blue Angel. I don't have incidence meters so cannot tell you how they sit in degrees. The nose-down attitude of the Atlas is possible an advantage for landing...it tends to bounce less...but both are very similar and it's early days yet.
19 Mar 2016 17:42 - 19 Mar 2016 18:00 #8307 by Phil Ford
With reference to the Curare and other trike gear generally, Jon told me that the comp boys used to have nose down attitude to help stick it down and avoid bounces on landing.
Last edit: 19 Mar 2016 18:00 by Phil Ford. Reason: Added On Landing
19 Mar 2016 17:59 #8311 by flyingpete
Don't worry Chris!! They will soon be out of shape after a few heavy landings B)
19 Mar 2016 18:13 #8314 by Chris001
Very true Pete, and I'm probably doing my best to over think things, but this being the first plane I've built I've not yet got the experience to say 'that will be fine'.
That's interesting to know, thanks Phil.
Time to create page: 0.392 seconds
