Fsky Taranis X9D Plus
02 Oct 2017 08:30 #13928 by Phil Ford
No I had not seen that. I will have to get one of them or maybe two (got two gliders);) Hi precision Vario was £19 on HK. X8R receivers £30.
02 Oct 2017 09:10 #13929 by Brian
Hi Phil, I tried to understand the Taranis video on YouTube unfortunately the video id 53 minutes and my attention span won't cope with that timescale. However, there was a load of stuff in RCM+E a short time ago. I don't know if this will help.
www.modelflying.co.uk/news/article/opent...-to-install-it/23076
I think I might end up using my old 35 Meg JR stuff.
02 Oct 2017 14:26 #13931 by Phil Ford
Brian, I have watched quite few of the videos, some are useful but some ramble on so much I lost attention too. I would much rather read the info (at my pace) along with decent images at each stage.
02 Oct 2017 15:48 - 02 Oct 2017 16:00 #13936 by Phil Ford
Written up the programming in Companion and wrote to TX. Used the Fox fuselage to check results (elevator & rudder). Compared to JR the rates % need to be lot lower than I expected. Although I have set elev and rudd to the 3 position switches It appears that I am only getting high and med, Ignores low rate.
Got timer running off throttle when above idle :)
Next job is "do I have to set both ailerons up independently or use a mix".
Last edit: 02 Oct 2017 16:00 by Phil Ford.
02 Oct 2017 17:28 - 02 Oct 2017 17:29 #13937 by Chris001
The equivalent Spektrum servo travel is -80% to 80%
I use the output tab to set servo end points.
I notice you've set up the switch to be (!SA) are you sure you don't want to pick the one with out the '!' i.e. (SA) I cannot remember what the '!' signifies but I'm pretty sure you don't want it ;)
Why are there two inputs for flaps?
Last edit: 02 Oct 2017 17:29 by Chris001.
02 Oct 2017 18:59 #13946 by Phil Ford
Chris001 wrote: Why are there two inputs for flaps?
Flaps? Two servos.
I'll check the switches again for no ! But the servos worked.
Yes the throws are massive at 100%. i'll set end points at 80% as Spektrum.
So much easier to program on the PC.:)
02 Oct 2017 19:12 #13949 by Chris001
You only need one flap input, but two flap outputs just like your ailerons....
For two ailerons you need to set it up in "Mixes' but in reality all you're doing is assigning two outputs the same input:
So click on the CH?? (this relates to the CH on the RX) you want to be the other aileron on, a in new dialogue box opens, select the source .i.e. the aileron input [I4]Ali in my example:
You can reverse the servo direction here by putting a - next to the 100 weight, or do it in outputs. However don't do what I've just noticed I've done, invert it here then inverted it again in outputs!
02 Oct 2017 19:26 #13951 by Chris001
I noticed you've put the rates for each control surface on a different switch, I'd never be able to dance around all the switches when flying, limited mental capacity on my part no doubt. I know we all fly differently and all have our own preferences, but the least amount of switch flicking the safer I feel. So I do everything on two switches, one is motor on off the other is a three way, and for the Mythos that is, Take Off/Landing, Flight & Spin. On the Alas (RIP) the retracts were also on that switch.
03 Oct 2017 08:05 - 03 Oct 2017 08:10 #13954 by Phil Ford
Thanks Chris. Well spotted regarding the !SA when it should be SA etc , etc
Two servos? I wondered if that is how it was done. That'll make it simpler in Mixes.
I have only set two rates. The OpenTX Guide suggests giving the unused switch position a value because strange things may happen if the radio does not read a value - ie; servo just "stops"
Rate Switches. Being a JR man I found it useful. eg; might want high rate elevator to taxi over rough terrain to stop nose overs but don't need to change the Ail or Rudder
For glider though could use one switch (Flight Mode) Launch, Cruise, Land. Rates are automatically set. That was how the Fox was originally set up on the DSX9
Thanks for eepe, I study it later.:)
Last edit: 03 Oct 2017 08:10 by Phil Ford.
03 Oct 2017 09:29 #13955 by Chris73
Replied by Chris73 on topic Fsky Taranis X9D Plus
Seems like a huge amount of work to just set up some dual rates and expo :S :S
Time to create page: 0.401 seconds
