Fsky Taranis X9D Plus
05 Oct 2017 11:45 #13981 by Brian
Thanks Phil, if you don't hear from me for a while I'll be scratching my head and waiting for the lights to come on.
The program downloaded and even better, it installed!
So here goes.
Catchyalater.
05 Oct 2017 11:57 #13982 by Chris73
Replied by Chris73 on topic Fsky Taranis X9D Plus
Phil, JR stuff is still available. the JR brand was taken over my another company, but it is still the same product being made in the same factory
So if you like your JR products there is no need to change
  • Stuartmck
05 Oct 2017 12:01 #13983 by Stuartmck
Replied by Stuartmck on topic Fsky Taranis X9D Plus
A manual for the X9D plus is advertised by T9hobbysport.
Stuart
05 Oct 2017 13:19 #13985 by JonTappin
Replied by JonTappin on topic Fsky Taranis X9D Plus
Chris73 wrote: Phil, JR stuff is still available. the JR brand was taken over my another company, but it is still the same product being made in the same factory
Chris, you got in before me!
Since Phil has now twice posted that JR are no more, I thought I had better post to clear this up. The following is directly quoted from an email I received very recently from MacGregor Ind, the UK agent for JR.
"JR is still running as a company- BUT they are currently not designing or having anything produced (for the hobby market).
We are dealing with the factory in Malaysia directly who are producing current items like rx's under licence.
Also, like with most Japanese manufacturers they have/had a preferred shop who they work/worked with closely. This is RC Japan who have taken on all of the remaining stock, some design engineers and are also helping to finance the factory. They are working on new products and are using the JR name, again under licence."
I have recently received some new DMSS receivers from stock coming in from the new supply source and more stock is expected.
If you already have JR equipment and it is working ok, there is absolutely no need to change. The older gear was running Spektrum transmission so Spektrum receivers are compatible anyway.
MacGregor are still providing service support for DMSS based systems and Mike Ridley in Southampton will provide service for JR 35MHz and DSM2 equipment
Contact: Mike Ridley
modelradioworkshop.co.uk/contact-details/
05 Oct 2017 16:31 #13993 by Phil Ford
Yes Jon. I read a similar quote on an Aussie forum recently. I really wanted a Zero 11 but none around. So decided if I could handle the learning curve I would go OpenTX. As I said previously I have had no issues with my DSX9, a good buy (which you recommended) without doubt and it is able to use Spektrum DSM & DSMX receivers. But just as I had to turn to Arduino ATmega programming to make my own Nav light systems I jumped to OpenTx for the options it gave. Plus of course gave me the head scratching, confused, puzzled expressions I craved for.:S ;)
05 Oct 2017 17:19 #13998 by Chris73
What was you said about some of the information on here Phil??
The point Jon and myself were making is that twice in this thread you said that JR were no more, which simply isn't true, also you couldn't have looked very hard as I bought a new JR XG11 along with two new JR receivers only a couple of weeks ago
If you are using JR and not having any issues then keep using it, if you fancy a change then thats fine too
05 Oct 2017 18:14 #14000 by Phil Ford
Chris73 wrote: I bought a new JR XG11 along with two new JR receivers only a couple of weeks ago
What? Wished you had mentioned it earlier. :(
05 Oct 2017 18:52 #14004 by DaveBright
Replied by DaveBright on topic Fsky Taranis X9D Plus
Interesting there's been no mention of Jeti as an alternative..... fine radios too
05 Oct 2017 19:33 #14007 by Phil Ford
DaveBright wrote: Interesting there's been no mention of Jeti as an alternative..... fine radios too
Damn I missed that one! And a few others me thinks. That the thing that looks like a box, wiv sticks on it and runs on thermionic valves - Retro?
Back to subject ;) Getting the hang of programming this thing now. Done my Phoenix 2M glider. I have got it to tell me half flap, flaps down, flaps up too. Hi Rates, Lo rates warnings and timer on throttle stick. Surprised that 80% travel is equivalent to 100% on JR.
06 Oct 2017 07:32 #14017 by Brian
Taranis has a lot to offer, if you can find it and make it work. I downloaded the Taranis "simulator". Didn't take me long to realise that I wasn't going to get to grips with the system without a lot of practice. Then I spent an hour or so wondering "why did it do that?". I pressed the "+" button, well I think I did. Finally I gave up, I considered a cheaper model, possibly easier to program, as suggested by Mike , then I looked at a second hand DX9 on the BMFA website, it seemed like a bargain, lots of things like receivers and varios etc. I had the idea that it would be easier to program the real thing. Then I wondered "if it's so good, why sell it?"
I think perhaps I'll stick with JR/Spektrum, Perhaps the problems that I've had stem from lack of care in aerial positioning and untidy cable runs.
Thank you all for the suggestions and help.
