Extreme Flight 104" Extra
9 years 8 months ago #7983 by Chris73
Replied by Chris73 on topic Extreme Flight 104" Extra
Don't think the pipes will help with that, but I have got a new reed block, reeds and carb diaphragm , plus all new reed block and carb gaskets. Hopefully that will sort it, oh and a new set of plugs
9 years 8 months ago #7985 by flyingpete
Replied by flyingpete on topic Extreme Flight 104" Extra
Nice work Chris!
9 years 8 months ago #7987 by Chris73
Extension leads made and braided for the tail, I used powerbox cable and crimps, using their crimping tool made this fairly quick and easy. Apart from setting up the throws that's the tail finished. Going to start making the leads for the wings now, while the wife has volunteered to go up B & Q to get some silicon so i can fit the landing gear cuffs :)
9 years 8 months ago - 9 years 8 months ago #7988 by Chris73
That took longer than I thought but the extension leads for the ailerons are now made and braided, also fitted the servos and control rods. Just got to set up the throws and the wings are finished :)
Last edit: 9 years 8 months ago by Chris73.
9 years 8 months ago - 9 years 8 months ago #7990 by flyingpete
Bloody hell chris!! You will need to have a lay down before you burn yourself out :P
Great job,like the new powerbox lead's ! Must give them a go
Last edit: 9 years 8 months ago by flyingpete.
9 years 8 months ago #7993 by Chris73
Didn't get much done this afternoon, took the 3W out of the Yak and then replaced the reed block with an Ali one, plus replaced all gaskets, then stripped and cleaned the carb, replaced the diaphragm and all gaskets and put in a new set of plugs for good measure.
Hopefully get the engine mounted and plumbed in tonight.
