Extreme Flight 104" Extra
9 years 8 months ago #7975 by Chris73
Replied by Chris73 on topic Extreme Flight 104" Extra
Got a bit done tonight, run the iron over everything, CA everything I could get to, fuel proofed the landing gear plate, hinged the elevators and rudder. While the epoxy was drying I plumbed and fitted the fuel tank and then went back and epoxied on the control horns to the elevators
9 years 8 months ago #7976 by Chris73
Fuel tank fitted :)
9 years 8 months ago - 9 years 8 months ago #7977 by AlanF
Replied by AlanF on topic Extreme Flight 104" Extra
I like the colour scheme.
Was the CA added as a precaution or were there signs of a lack glue. I know it's not the same quality as the EF but my Giles had one wing tube largely un-attached at the root and on trial fitting the stabs on the Edge the anti-rotation pins disappeared into the stab root. They're going to be a b*st*rd to get back out :(
Have you decided on engine and servos yet?
Last edit: 9 years 8 months ago by AlanF.
9 years 8 months ago #7978 by Chris73
The CA was just added as a precaution, everything seemed to be well glued but Extreme Flight recommend you do this, just in case
Engine will be 3W110 with MTW tuned pipes, servos are Savox 1270TG
9 years 8 months ago #7981 by Chris73
Ailerons now hinged, servo's fitted to the stabs and the landing gear mounted.
Tomorrow's jobs
1) Install the servos in the wings and make up the leads
2) Fit engine and exhausts
3) Start making the extension leads for the elevators and rudder
I will take some more pics tomorrow when I start making the leads
9 years 8 months ago #7982 by
Replied by on topic Extreme Flight 104" Extra
Sounds like you are making good progress Chris, will the MTW tuned pipes help with your lack of power at take off? I'm assuming you've gone with your original plan and pulled the servos and engine out of the Yak?
