Extreme Flight 104" Extra
9 years 8 months ago #8032 by simondean
Replied by simondean on topic Extreme Flight 104" Extra
Yes your right Pete ,slip of the fingers it's M5 .
9 years 8 months ago #8043 by JRI
Replied by JRI on topic Extreme Flight 104" Extra
I have a similar problem to Simon - the supplied M6 spinner screw doesn't reach or fit the M5 crankshaft thread and adapters are n/a. But I Found High-tensile M5x120 & M5x130 on the modelfixings website at www.modelfixings.co.uk/high_tensile_steel_caps.htm .
The longest screw reaches the crankshaft for my spinner but I will need to sleeve the nose of the spinner from 6mm to 5mm.
9 years 8 months ago #8044 by simondean
Found a company dealing with M5 in suitable length but they only supply to trade . Got a name in the area but not had time to investigate yet.
9 years 8 months ago #8045 by kevinross
Replied by kevinross on topic Extreme Flight 104" Extra
simondean wrote: Found a company dealing with M5 in suitable length but they only supply to trade . Got a name in the area but not had time to investigate yet.
Simon - also available at westfield fasteners are these which you could use in combination with some HT studding to extend the the longest 5mm bolt . Bottom the spinner bolt and a piece of studding into this long nut.
www.westfieldfasteners.co.uk/A2_Nut_HexL...LRhMsCFRYTGwodkNQNkg
9 years 8 months ago #8047 by simondean
Thanks for the info Kevin,may be easiest solution.
9 years 8 months ago #8049 by Chris73
Replied by Chris73 on topic Extreme Flight 104" Extra
Simon, is yours done apart from the spinner??
Graphics are going on mine today, and then it's just a case of getting the C of G right and she's finished
Time to create page: 0.262 seconds
