Rubin
5 years 6 months ago #22000 by MikeSeale
And I decided to make just the belly pan removable and attached with magnets...and a dowel at the back.
The following user(s) said Thank You: 4Pedalsfly, Phil Ford, John Bannister, Brian
5 years 6 months ago #22007 by MikeSeale
My hay fever kicked in big time today and setting foot in the workshop set me off so very little done today. Instead I spent the time indoors with some photography.
5 years 6 months ago #22020 by MikeSeale
Hay fever is under control today - just one sneeze so far!
I only managed a couple of small tasks yesterday. I added aileron servo trays to the wing and glued and sanded to lower front decking to match the top of the fuselage.
5 years 6 months ago #22022 by MikeSeale
Today it was time to make a cowl. I've never done this before so bear with me. Three blocks of Styrofoam are glued together and then cut to rough shape using a hot wire. A couple of hours of sanding and it looks like a cowl.
5 years 6 months ago #22023 by MikeSeale
The next step is to cover the cowl in packing tape and glass it. I'll probably then use the 'lost foam' technique, but might use the cowl as a plug for a mould. Here's the model at this stage looking a lot more like a Rubin.
5 years 6 months ago #22026 by Phil Ford
Good progress Mike. If you make the cowl using the styrofoam then in theory it should slip over the front of the fuselage?
