DH VAMPIRE
15 Jul 2015 13:23 #5135 by flyingpete
Had a bit of spate time so I thought I would mark out the under side of inner wings for the flaps and wheel Bay.Most of rib no 3 will be removed in the wheel Bay area,so to put back some strength the underside sheeting will have some glass cloth and z-poxy
15 Jul 2015 13:31 #5136 by flyingpete
Also taped down some brown paper to the bench and marked out for the formers, and the six crutch supports which are screwed down to the bench
16 Jul 2015 12:13 #5139 by flyingpete
Fuselage crutch supports made up with centre lines marked ready to be screwed to the bench.
Everything will become clearer once I have made the crutch and formers in place.
Going to meet David later to pick up all the wood etc.
16 Jul 2015 16:22 #5140 by DavidTappin
Nice to see you Pete but not all the wood etc we missed a bit!
16 Jul 2015 16:32 #5141 by flyingpete
Neve mind David, at least those bit's are not needed for a week or so
16 Jul 2015 18:57 - 16 Jul 2015 18:57 #5142 by DaveBright
My building experience tell me they're for the left and right hand bits of something.........
Last edit: 16 Jul 2015 18:57 by DaveBright. Reason: Spelling
16 Jul 2015 19:14 #5143 by flyingpete
DaveBright wrote: My building experience tell me they're for the left and right hand bits of something.........
Dave, I think you should stick with the fruit and veg as you know what you're doing with that!:-P
16 Jul 2015 19:22 #5144 by flyingpete
Made a start on the fuselage crutch. Picture shows the upper rear crutch constructed, front lower crutch will be built tomorrow and the two will be glued together with 4 spacer blocks.
17 Jul 2015 13:59 #5153 by flyingpete
OK then,front lower crutch built and joined.to.upper.Formers are slipped over the crutch and the assembly pinned to the supports.Formers 2 through to 12 are lined and leveled a tacked in place.The ply root rib has a centre line and it is very important that it is level with the board and tacked in place. turn the assembly around and do the same.Once I'm happy I will run pva over the joints and it's now.ready for the stringers.
17 Jul 2015 15:45 - 17 Jul 2015 15:46 #5154 by Phil Ford
Nice one Pete :lol: That made me laugh from what so far has been a dull day peeling spuds and fixing rc stuff I bent yesterday... :oops:
I still think David should give it to me as I am going to have a new big van in the future to get big stuff up the field.
Last edit: 17 Jul 2015 15:46 by Phil Ford.
Time to create page: 0.542 seconds
