DH VAMPIRE
06 Aug 2015 09:12 #5428 by JRI
Replied by JRI on topic DH VAMPIRE
Awesome job - is there a common spar for the wings or are they individually attached and braced to the fus'?
06 Aug 2015 12:45 #5431 by flyingpete
John, the outer panels are on tubes,the inner panels are glued to the fuselage structure with a 1/4 ply dihedral brace on the front and a 1/8 ply brace on the rear.Incase David decides to 3d the vampire I have gone belt and braces by adding extra 1/8 light ply shear webs around these joints and pinned the whole lot with1/8 dowels.
06 Aug 2015 20:12 - 06 Aug 2015 20:12 #5436 by Phil Ford
flyingpete wrote: In case David decides to 3d the vampire I have gone belt and braces by adding extra 1/8 light ply shear webs around these joints and pinned the whole lot with1/8 dowels.
I do believe that is called "over built" Pete as kits go...... ;) Anyways, David only does 2D, but Jon on the other hand........ :whistle:
Last edit: 06 Aug 2015 20:12 by Phil Ford.
06 Aug 2015 20:21 #5437 by flyingpete
Phil,do you think Jon is planning on doing 100 mph snaps :woohoo:
06 Aug 2015 20:37 #5442 by Phil Ford
"do you think Jon is planning on doing 100 mph snaps"
No I don't think so Pete but after the Impressivo - a different story.. :lol:
27 Aug 2015 22:53 #5646 by 4Pedalsfly
Replied by 4Pedalsfly on topic DH VAMPIRE
Guys - Just spotted one for sale complete on the BMFA website, built from the Kerry Sterner plan & test flown
by Steve Holland. This plane was featured on the front cover & reviewed in R.C.J. Int April / May 2015.
Seller is Tony . A . Pearson & is selling it because he has nowhere to fly it ?
Video of test fight available on
https.//video.com/10735
Looking forward to seeing David's in the air.
Colin. A
14 Sep 2015 17:00 #5985 by flyingpete
Well holiday season is nearly over for me so time to knuckle down and do some more on the vampire. The next stage is to glass the airframe with light glass cloth and resin. This is a very slow and messy job so to make best use of my time I am going to glass my panther at the same time as I will be able work on one model while the other is drying and only one mess to tidy up.
I'm hoping when I get back tomorrow the resin and cloth have arrived.I have a lot of prep work to do on both models first so will post some pics of the glassing process when I start later this week.
16 Sep 2015 19:32 #6032 by flyingpete
Started back on the vampire ,got most of the filling done.Hopefully if the weather plays ball tomorrow i can get the model outside and give it a final sand and a coat of resin.
I always seal the balsa with a coat of resin and flat out with 400 paper first otherwise if you don't the balsa can act as a sponge and leave dry spots when you lay up the glass cloth.While i'm on the subject of glassing a model you can lay up the cloth in two ways,some people like to roller a coat of resin on the model and lay the cloth on the wet resin or the way i like to do it is lay the cloth on the dry airframe and using a 50mm brush work the resin in, working from the middle out to the edge,using only enough resin to stick the cloth down and remove any excess resin with a credit card.Once it has cured i will go over again with the 400 paper and then apply a second coat of resin.
Never try and flood the cloth to fill the weave as you will end up with a ripple surface which will be a nightmare to sand back and get a nice smooth finish.Much better option to make sure the weave is full is to spray on a coat of high build primer and sand back,much lighter than resin and easy to sand back.
Pete
16 Sep 2015 20:53 #6033 by DaveBright
What resin do you use Pete?
16 Sep 2015 21:14 #6034 by flyingpete
Dave ! I will be using Delux products finishing resin,very easy to use and it is easy to sand and low odour.It's more expensive than other resin's but well worth it as you will see on both models when they are done B)
Time to create page: 0.519 seconds
