DH VAMPIRE
23 Jul 2015 09:20 #5252 by DavidTappin
Dave, where did you find those DerJet pictures?
23 Jul 2015 09:58 #5254 by flyingpete
DavidTappin wrote: Pete wrote of
fabricate some balsa ducts
Pete, when fabricating the ducts don't forget that I want to get the turbine as far forward as possible otherwise there won't be enough lead on the roof of St Mary's Fordingbridge to get the C of G in the right place.
With the Simjet Kerry Sterner shows in position on the plans he told me that he needed over 3lb of lead in the nose.
Yes David i remember you saying about getting the turbine well foreward,your lucky you still have some lead left on your church :ohmy:
The ducts are not a problem as they can be fitted at any time from the inside so next time we meet up i will take the turbine with me
23 Jul 2015 10:57 #5255 by DaveBright
23 Jul 2015 11:53 #5256 by flyingpete
Dave B,I would love to get into the jet jockey world but can't see my limited modeling fund stretching to a turbine any time soon :(
I'm working on the underside of the inner wings today and will get some pics up later
23 Jul 2015 13:13 #5259 by flyingpete
OK then! Port and starboard inner wings have all the strengthening added.End grain balsa shear webbs to front and rear spars solid balsa block around the wing dihedral brace.Thin f/g sheet added to undercarriage Bay to add strength after the rib has been removed. I also added some.support to the wing tube socket and mixed some micro balloons with epoxy to form a fillet and leading edge added.The wing will now be sheeted and air brake,flaps and wheel wells cut and epoxy undercarriage mounts.
24 Jul 2015 16:35 #5277 by flyingpete
Constructed outer flaps and air brakes.Note the trailing edge drops away with the flap.As the trailing edge is sanded down to fine edge I am going to add spruce strip to add strength and avoid warping. Pictures show surfaces fully deployed.
24 Jul 2015 18:23 #5279 by DavidTappin
Pete, what hinges are you using on the airbrakes? When those panels deploy at 100 mph there will be quite a pull on the hinges and with the worst case of one breaking away it would take a better pilot than me to recognise what had happened and take defensive action before loss of control ensued. I believe that was how Kerry Sterner lost his 1/4 scale version!
24 Jul 2015 19:38 #5280 by flyingpete
I'm planning on using heavy duty robarts buried into balsa blocks, they ain't going nowhere David
25 Jul 2015 14:35 #5285 by flyingpete
U/C bay's cut out,hardwood bearers going in with some balsa strengthening.
A note to rookie builders,as with any u/c mounts they need to be fairly solid but they need to rip out on a very hard landing as to not take the wing structure with it.I would also recommend not to bolt retracts in but use good quality self tappers.
25 Jul 2015 16:37 #5287 by flyingpete
Trial fit of u/c leg
Time to create page: 0.418 seconds
