Fsky Taranis X9D Plus
7 years 11 months ago #14201 by MikeSeale
Use Companion and open the settings window. Make sure you have the LUA box ticked. Then flash the transmitter again.
7 years 11 months ago #14202 by MikeSeale
Brian wrote: my X9D shows a comforting "D16". So my second hand bargain is EU compliant, crikey!
D16 does not mean it's got EU LBT firmware.
7 years 11 months ago - 7 years 11 months ago #14208 by
Hi Brian,
When you updated your radio, did you also update the SDCard content for 2.2.0?
OTX 2.2
It's the first thing bellow the title: Download links: at the bottom of the page. The SD card contains the 'Wizard' in the folder called scrips.
Last edit: 7 years 11 months ago by .
7 years 11 months ago #14216 by Brian
Hello Chris, I've got myself a bit confused with the Taranis. i thought I'd sorted it when I got it up to 2.2. Since then I've tried to update the bootloader to match, but it doesn't seem to respond in the same way that other Taranis transmitters do on YouTube. Thank you for the gen on updating the SD card, somehow I missed the fact that the card and the transmitter are separate. I was assuming that a single update did it all.
7 years 11 months ago #14217 by Brian
Hello Mike, today I tried to flash the EU-LBT firmware using a program called DFU Dfuse. Caused more trouble for myself...again. Uninstalled the program and ended up with a flat transmitter battery. Try again tomorrow.
7 years 11 months ago #14236 by Brian
Finally the bootloader was updated to version 2.2. I thought that was that. Now I find that it isn't just a matter of binding the receiver to the Tx, the receiver has to be flashed with the latest firmware first. I did a quick run through this morning, looks more complicated than updating the transmitter.
Time to create page: 0.279 seconds
