Fsky Taranis X9D Plus
11 Dec 2017 12:16 #14947 by John Bannister
Replied by John Bannister on topic Fsky Taranis X9D Plus
Brian as there have been no further updates I assume if couldn't be fixed on Friday at the AGM so if it's scrap can I have it.
John
11 Dec 2017 15:42 #14948 by Brian
Hi John, the Taranis isn't scrap after all, it was brought back to life on Thursday evening. The problem was of my own making, not faulty equipment. I'm waiting for a module that will enable two receivers to be fitted into a model, these will be a Taranis and a Spektrum. If it works it might be of use in a trainer instead of using a buddy lead.
Hope you can find a cheap Taranis x9d .
Brian
20 Mar 2018 18:07 #16101 by Phil Ford
Totally baffled! Plugged in a Frsky GPS V2 into an S8R receiver. The Taranis X9D displays after a warm up GPS info. But the info is not being logged (the sensors are all set to logs. In fact the logs do not show any GPS titles at all in the left column. :( I have surfed n surfed but no joy on why.
Have I missed a switch. Or does the GPS not like the S8R (integrated 3 axis gyro) although I cannot see any reason why they would interfere with each other.
