Minus Thermic
8 years 9 months ago #11210 by JonTappin
MikeSeale wrote: Having seen your "Christmas Story", all I'd say is "if the cap fits..."
:lol:
8 years 9 months ago #11213 by Phil Ford
Replied by Phil Ford on topic Minus Thermic
:lol: Yes maybe but my story only took a few minutes. ;)
8 years 9 months ago #11221 by
MikeSeale wrote: ...A solution would be to use very short elevator horns, but I had already cut them to 8mm and decided that even shorter would not be acceptable because:
1. Shorter horns would give limited 'grip' for the heatshrink and
2. Shorter horns would result in MORE elevator movement than needed and I would have to dial down the throw using travel limits, and this would reduce my resolution
So the elevators were removed and a couple of mm cut from the ends in order to increase the gap. With hindsight, only 1mm was needed
Hi Mike, did you settle on 8mm horns for both elevator and ailerons? And will you do the same on the Acro, or maybe go longer on the ailerons?
8 years 9 months ago #11224 by MikeSeale
Go longer if you can
8 years 9 months ago #11290 by MikeSeale
Do I need to call operation yew tree?
8 years 9 months ago #11291 by Chris73
Just to be clear, this was gromet. NOT ME
