Minus Thermic
8 years 10 months ago #11090 by MikeSeale
Looking good, Chris. When you try to fit everything in make sure you accept that you're probably going to have to remove the case from that lovely new receiver.
8 years 10 months ago #11091 by
That's going to hurt ;) I presume you clear heatshrunked (have I just made up a word) the RX after removing the cardboard outer wrapper?
8 years 10 months ago #11092 by MikeSeale
Chris001 wrote: That's going to hurt ;) I presume you clear heatshrunked (have I just made up a word) the RX after removing the cardboard outer wrapper?
I Kaptoned...thinner than heatshrunking it.
8 years 10 months ago #11126 by
I've just found a sure fire way to put myself into a bad mood. :angry:
Trying to cover the same wing tip, no less than five (insert expletive) times, after the failed second attempt I did the other wing tip first go. The icing on the cake is that the purple transparent film leaves the colour on the balsa when removing the film.
Thankfully both are now done, so I can get on with the Ailerons.
8 years 10 months ago - 8 years 10 months ago #11127 by Phil Ford
Replied by Phil Ford on topic Minus Thermic
Chris001 wrote: the purple transparent film leaves the colour on the balsa when removing the film.
Twern' t Profilm then? :P Cheapskate.... :lol:
Looks alright now though. That's good enough. I have had enough film swearing myself.
8 years 10 months ago #11128 by
Look here sunny, I splashed out on Hobby Kings finest... Yep I'm a cheapskate.
Time to create page: 0.365 seconds
