Scratch Built Hannibal
7 years 3 weeks ago #17121 by DavidTappin
Replied by DavidTappin on topic Scratch Built Hannibal
Nice work Brian, but I should keep going if I were you, as soon as it cools down that will probably be because it's raining.
7 years 3 weeks ago #17123 by Phil Ford
DavidTappin wrote: Nice work Brian, but I should keep going if I were you, as soon as it cools down that will probably be because it's raining.
:lol: Realist David!
Let's hope it flies as well as the build Brian. ;)
7 years 3 weeks ago #17126 by 4Pedalsfly
Good work Brian - look forward to seeing the model at Cashmoor, have you finalised which motor will
be used ?
My workshop has an ex- conservatory roof, great in the winter, warms up nicely with a little sun.
Killer at the moment 50 degrees when we got back home today.
7 years 3 weeks ago #17127 by Brian
Thanks Colin, I'm going to use the Saito 1.25 as it is already converted to run on petrol.
7 years 16 minutes ago - 7 years 15 minutes ago #17323 by Brian
I made several attempts to spray the Hannibal's markings, but the covering doesn't seem to be paint friendly. Finally, the Blue Peter training cut in, and I completed the job using sticky backed plastic. Fortunately no egg cartons or toilet roll middles were involved. The vinyl shapes were no trouble to apply, I used the "dry hinge" method suggested by Mike, much easier than I thought and the results are quite satisfying. The model is unrealistically shiny at the moment, I intend to coat it with satin finish fuel proofer.(If I can get it to stick)
I've two cowls for the model, the original was badly dented on the old Hannibal's first flight, I got a spare cowl from Inwood Models, but by the time it arrived, I'd beaten out the worst of the dents. Now I have to make a decision, use the old cowl and have the model look like an Eindecker, or use the new one and have the model look vaguely like a Fokker DR 1.
Any comments on which would be the most suitable should be written in pencil on a new £10 note and addressed to me
Last edit: 7 years 15 minutes ago by Brian.
6 years 11 months ago #17324 by Phil Ford
That's looking really nice now Brian.:) Now for scale looks it needs the dented cowl to show it has done some glorious combat and flying. Are you going to slope soar it as a PSS? :P
Time to create page: 0.294 seconds
