3D Printing
04 Feb 2020 19:04 #21595 by Brian
Finally got down to the shed today, spent a while hunting out suitable screws to hold the motor. The designers didn't make assembling the motor to the model an easy task. The holes for the motor mounting screws are under 3mm, so the screws had to be "screwed" in. It took me quite a while to figure out a way to get things lined up. Finally it all came together and at last the motor was fixed. When the prop hub/spinner was attached to the motor shaft, I could see that down and side thrust had been built in. That's good, 'cos dismantling the motor and adding packing washers wouldn't be a fun thing to do. So far the servos are centred and fitted, the motor is in and plugged in to the ESC, No blades will be fitted until the motor runs the right way! HobbyKing have refunded the cost of the motor they didn't have in stock, and I've saved a decent sum by getting four LiPos from them, so it can't be too bad.
04 Feb 2020 20:38 #21597 by DaveBright
Good stuff Brian! I will collect those specially commissioned parts soon I promise!
05 Feb 2020 19:01 #21602 by Brian
Hi Dave, I'll bring the thingys to the meeting on Friday. See you then.
B.
07 Feb 2020 12:26 #21623 by Brian
Today I found the perfect excuse to not fly the Joker. A new piece to be left behind. The absence of the piece only being discovered after assembling the model on the field and wondering "What the ***!!!***" did I do with the darned thing?
The attached photos will give you some idea of what the missing part is, and does.
The ultimate safety device for an electric model, a cheap 'n cheerful Deans plug in a 3D printed holder.
The plug isn't shown 'cos HK haven't delivered the connectors I ordered............yet. I'm hoping I don't get a "On back order" message.
07 Feb 2020 15:15 #21627 by Brian
Shortly after I posted the last article, the delivery from HK arrived! The new Deans connector bodies are very different from the original design. Happily the terminal sizes and pitch are compatible with the old design. At least the new connectors come with a snazzy terminal cover, this also eases the old problem of getting the connectors apart without breaking a finger nail.
07 Feb 2020 18:32 #21630 by DaveBright
Brian wrote: Hi Dave, I'll bring the thingys to the meeting on Friday. See you then.
B.
Hi Brian, afraid I cannot make tonight
13 Feb 2020 17:54 - 13 Feb 2020 17:59 #21645 by Brian
The Joker is almost complete! Bit frustrating this week, I ordered some small but vital parts last week expecting them to arrive by at least Wednesday. Had a 'phone call yesterday, the usually efficient people seem to have caught "HobbyKingitis" and at this late time have told me there's no stock of one item, so they are holding the order until they have everything.. I'm going to have to take up a hobby that doesn't involve trying to get bits that are advertised but are unobtainable.
Today I made up the pushrods for ailerons and flaps by rummaging through boxes of "useful stuff" that hadn't seen daylight since I don't know when. Finally managed to assemble four clevises, four bits of threaded rod and amazingly, four M2 hex nuts. The design really needed two clevises per pushrod, but I had to make do with one clevis and a "Z" bend at the servo end of the rod. I held the ailerons and flaps with masking tape while fitting the pushrods, I don't think I'll need to dismantle anything when I finally get to fit the elusive cyano type hinges.
The wings slid into place with no fuss, but a snag arose with the canopy. This fits the fuselage when the wing isn't in position, there isn't any mention of adjusting the wing centre section where it butts on to the fuselage, but sanding off a couple of millimetres was the only way to get the canopy to sit neatly. Finally, sanding off about 3mm from the rear face of the wing centre section made enough room for the canopy to settle with its front edge level with the seating in the fuselage, and the moulded detent at the front to give a gentle "pop" as it located.
With everything apart from the receiver and prop blades on board, the weight came out at 1230 grams, I was surprised as the model feels quite heavy. With mistakes and re-makes, the printing time was a few minutes over 90 hours, I didn't keep a record of the time to assemble the "bits".
The next episodes of the Joker story will be on a different Forum, it might be a mention of a remarkable first flight at Cashmoor, but it is more likely to be in "Tales of Stupidity".
Last edit: 13 Feb 2020 17:59 by Brian. Reason: Left out a bit of information
13 Feb 2020 18:40 - 13 Feb 2020 18:41 #21648 by Phil Ford
Nice work Brian. Looking forward to the maiden sometime this year. I nearly always use suppliers who actually hold stock rather than show items to fill their web shop catalogue. :( On the other hand you could have saved 90 hours and bought a HK Phoenix 1600 PNP :lol:
Last edit: 13 Feb 2020 18:41 by Phil Ford.
12 Mar 2020 13:18 #21790 by Brian
Latest from Eclipson. Looks good, shame about the peeling graphics, seems to be a problem with PLA, doesn't like "sticky backed plastic"
www.eclipson-airplanes.com/mxs-r?utm_cam...8a-8a85-fcfd1e24ff78
25 Sep 2020 12:13 #23376 by Brian
Since last March, the 3D printed Joker has done nothing but collect dust. I lost a good deal of enthusiasm for the project when I realised (too late) that the model isn't a powered glider at all. It is in fact something called a "Hotliner". A model that whizzes about at high speed isn't really what I like to fly. I suppose with the motor/ESC removed it would make a reasonable slope soarer, but that would take some thought and extra work to accomplish. As I'm not into either disciplines it seems as though I've printed and built a bit of a lost cause. However, all isn't lost as I gained a lot of experience with it.
