Stearman build
22 Mar 2024 10:25 #26775 by kevinross
I hope these Nav lights show well in flight
22 Mar 2024 10:29 #26776 by kevinross
Decided not to use covering film on the centre section so it's been glassed. Also the small ABS parts to provide a bit more strength (they were probably moulded 15yrs ago )
After 4 yrs i cant believe there is one part ready for paint !
22 Mar 2024 10:35 - 22 Mar 2024 14:58 #26777 by kevinross
Wings now ready for covering using DIACOV  which is 14cm wider than Oratex 60cm .  templates helped optimise the extra width. Oratex would have cost me over £250
Last edit: 22 Mar 2024 14:58 by kevinross.
22 Mar 2024 10:45 #26778 by 4Pedalsfly
Replied by 4Pedalsfly on topic Stearman build
Kevin - Looks really bright in the workshop, how about a garden night shot ?
Weather looking crap next week !!!
22 Mar 2024 14:17 - 22 Mar 2024 15:01 #26779 by kevinross
haven't used a TEX type covering for many years but this DIACOVis a sheer pleasure (purported to have better shrink ratio and adhesion properties than solar or ora TEX
Just amended the text above - i'm using DIACOV which is DIATEX with an adhesive backing
The tex version is applied with dope.
Last edit: 22 Mar 2024 15:01 by kevinross.
27 Apr 2024 16:06 #26802 by kevinross
All 4 wings now covered so the fuselage is next. Then i remembered finding a pic on the net of a full-size Stearman rebuild.
So spot the differences here !
28 Apr 2024 14:41 #26804 by Phil Ford
You need to change your shirt.
30 Apr 2024 21:53 #26805 by kevinross
At last - all 15 sections covered with about 9 running meters of Diacov.
31 May 2024 19:18 - 03 Jun 2024 11:05 #26819 by kevinross
Eventually got around to laying up the cowl and spats using the mould I made  a year ago. Bending the shaft on this oval roller was a bit help.
I made a balsa ring to reinforce the frontal radius to minimise the amount of resin and weight.
Last edit: 03 Jun 2024 11:05 by Phil Ford.
01 Jun 2024 10:10 #26820 by kevinross
Sheer brutality was the only way to split the mould but at last i have a cowl
Time to create page: 0.408 seconds
