02 Oct 2020 11:07 #23432 by Brian
The Kadet has at last got its windscreen and side windows fitted. The blue tissue trim was a lot of fun(?) and took a lot longer than I had thought. As the long drawn out build approaches the final stages, I'm kept awake at night trying to find a believable excuse to avoid the final act of flying it. This might seem odd, but a succession of "real" and "almost" crashes have made me a bit nervous. Perhaps I'll get to Cashmoor early one morning when, apart from John Bannister, there'll be nobody about. Comforting to know that JB is really good at finding bits of missing models.
02 Oct 2020 12:11 #23433 by Phil Ford
You can always ask a certain member if he will maiden it for you. Then you will know if it is down to YOU or the IDIOT in the cockpit. :lol:
03 Oct 2020 11:06 #23437 by Brian
That would be taking the easy way out Phil. I think that as long as the "nut" that holds the stick isn't "tight", the first flight of an "easy to fly trainer" shouldn't be a drama. It'll be on low rates with at least 20% expo..
07 Oct 2020 16:58 #23445 by Brian
This morning it took me a long time to realise that it wasn't raining and there wasn't enough breeze to stir the trees, a good time to do a bit of model building in the garden. Finally I put out the building board and got down to doing a bit more work on the Kadet. The underside of the fuselage is now covered in blue tissue, I made a start on completing the side trims, but realised I need to have the cowl in place to complete it. The OS FS .40 was duly bolted in and the plumbing was connected. Fortunately I'd left the fuel and vent lines a bit long, so assembly was easy but as usual, extremely fiddly, especially getting the fuel line onto the carburettor nipple, not much room between the bearers and the front bulkhead. The job was made a lot easier by using ex-NHS artery forceps. Previously I'd planned to use an OS FS .52, unfortunately I'd cut the cowl, even more unfortunately, the .52 has its throttle controls the opposite side to the .40, so I had to make a new hole for the main needle, and think about ways of patching up the original cut-outs. Finally I offered up the cowl and temporarily fixed it with four screws. It was a relief to find that the original fitting was OK and the spinner lined up quite nicely. Of course I had to make a mistake. I'd been perching the fuselage upside down with the wing fairing over the edge of the building board., this allows the fus. to sit nicely on the wing seating. That's fine as long as there isn't an engine bolted on to the front. I put the upside down model on the edge as usual, and it came as a bit of a shock when it promptly dived off. The windscreen didn't survive. The latest photos show the new screen pinned and with the glue showing as white streaks, they'll vanish as the glue dries out.
13 Dec 2020 19:52 #23835 by Brian
The Kadet isn't finished, I was within reach, but fate intervened and I had to take a trip to IKEA Southampton. A good thing to do if you've designed a new kitchen on IKEA's free software. The resident experts looked over my proposed design, seemed to approve, but suggested a couple of changes and additions. That was OK until I realised that it almost doubled the original price. It took two more trips to sort things out. By now it was almost November and outdoor building/finishing was no longer possible. It took a few days to get over the sudden cramp in my wallet when I paid for the kitchen stuff. Then it took a couple of days to clear the old kitchen to prepare for the new build. The past few weeks have been a confusing time of re-plumbing, re-wiring and re-plastering. I started to feel a bit unwell, it has been diagnosed as IKEAITIS. Hopefully, when Spring finally comes around I'll have regained my sense of humour and I'll get to finish the Kadet. I hope you've enjoyed reading about my adventures on the building board, in a way it was to lift the gloom of lockdown as well as to entertain and inform. In the meantime, Happy Christmas to all my readers and fellow club members, stay safe and lets all look forward to being free from the virus. Keep watching the Forum, I'll announce when the Kadet will attempt its maiden at Cashmoor, and keep an eye out for the first instalment of the Moonglow IV build.
13 Dec 2020 22:00 #23836 by kevinross
Best of luck with the Kitchen - as you know i'm no stranger to those diversions from modelling
14 Dec 2020 10:59 #23839 by Phil Ford
Kevin Ross wrote: Best of luck with the Kitchen - as you know i'm no stranger to those diversions from modelling
I got diverted too recently ;)
29 Jan 2021 09:36 #24122 by Brian
I checked that the Kadet was still OK after being abandoned in favour of the delights of struggling with an IKEA kitchen build. Apart from adding a receiver and battery, there's a strip of blue tissue trim to add to the front of the fuselage, then perhaps it won't be too long before we get some freedom and a spot of decent weather to go with it. While browsing the Outerzone the other day I came across this encouraging story, thought you might like to read it.
outerzone.co.uk/viewpoint/entry.asp?ID=11
09 Apr 2021 12:58 #24472 by Brian
The recent warm spell got me back out into the garden working on the long overdue Kadet. The winter in a damp shed hadn't been kind to the windscreen glue, I'd left it pinned after gluing it in place, the pins had rusted and stained the glued area, and the glue hadn't set in the cold and had run into places where it shouldn't. Finally I got the screen cleaned and re-glued, this time using plated pins. The blue tissue trim on the fuselage needed to be finished, but before I could do that I had to finalised fitting the engine cowl. Once again the winter and damp had made the cowl buckle and start to delaminate. Perhaps my idea of making a cowl from tissue and PVA glue wasn't one of my better ones. When balsa was plentiful, I made cowls from block and thick sheet balsa, unfortunately I don't have any now. Rummaging in the "bits box" I came across a piece of useful looking 1/2" sheet, useful but nowhere near enough to make a cowl. Then it occurred to me that it might be possible to saw curved sections out of the sheet, and make a cowl on the same principle as making a barrel. This would be perhaps the most economic way to use the small piece of sheet balsa. Fortunately, I had a pair of rejected wing tip blocks, they yielded a couple of small but useful pieces that were 1" thick, very handy for making the underside of the cowl. The photos more show how its going better than I can describe it. No doubt there'll be a good deal of filler in the joints, but its quite encouraging to find that even the curved offcuts can be used to fill a space.
10 Apr 2021 12:06 #24477 by Phil Ford
Novel way of cowling the engine Brian. I assume you will make a hatch so you can access items that inevitably will need twiddling with.
Time to create page: 0.405 seconds
