22 Apr 2022 14:48 #25801 by Brian
A few more "pix" to look at while I do some simple sums and marking out.
23 Apr 2022 07:04 #25802 by Brian
The LE of the aileron added and riblets to support the aileron horn fitted, TE of wing cut so that exact position of the inboard end of the aileron can be found after sheeting is complete. The wing structure will now be rolled on to the sheet and glued in two or three stages. The "hit and miss" spar webs are deliberate, the build instructions state that until the wing has been checked and no warps found, then complete the webs on front and rear spars. The webbing will be omitted from the bays in the aileron area, webs will be fitted between the spars after the aileron is cut away from the wing structure. This webbing forms an area to be sanded flat to give a mounting face for the sewn cloth aileron hinge.
24 Apr 2022 22:09 #25804 by Brian
The weekend fairly flew by as I measured, re-measured and then cut the parts for the servo mounts and servo cover plates. I'd left the wings glued, pinned and weighted overnight, this morning the pins etc were removed and I was relieved to find no warps. Today I fixed the first servo onto its mount and attached the mount to its bearers with tiny screws only 8mm long. I cut and fitted some scrap balsa to use as a support frame for the servo cover, made the servo cover from 2mm liteply and cut a slot in it for the aileron pushrod and clevis. With everything glued up, I took a break for lunch, and then wasted an hour watching David Attenborough's programme on the last day of the dinosaurs. Not wasted really! Sewed up the mystery of where all the dinosaurs went overnight.
Returning to the building board I did a final check on the alignment of the servo arm and elevator horn. Something wasn't right, almost 1/4" out. It took a while to sort out what had happened, I'd fitted the servo the wrong way round, fortunately it was only a case of taking out the screws and re-positioning the servo mount in the right place.
Repeating the procedure for the other wing (correctly this time) was a lot quicker.
No pix today, forgot to change camera the batteries again.
25 Apr 2022 12:50 - 26 Apr 2022 12:52 #25805 by Phil Ford
. Something wasn't right, almost 1/4" out. It took a while to sort out what had happened, I'd fitted the servo the wrong way round.
:oops:
Had you worried for a bit though didn't it?
Last edit: 26 Apr 2022 12:52 by Phil Ford.
30 Apr 2022 17:56 #25823 by Brian
Four days late with the reply, but... yes Phil I was a bit rattled at the time, at least it didn't take a lot of effort to get things straightened out. Since the last posting I've done very little, apart from making a few more mistakes. The plan calls for a 1/2" square hardwood undercart mounting, I had 3/4" X 1/2". No problem, I cut the ribs and ply doublers to accept the wider mounting. Then I decided to add a block to the end of the mounting, drilled for the U/C wire, and (hopefully) take the load imposed when landing and not get " floppy" due to lack of bearing area. I had some plain 3/4" X 1/2" beech, sawed off a couple of 1" lengths and epoxied them to the ends of the U/C mounting. With the epoxy nicely cured, I epoxied the U/C mounts into the wing. Should have had a better look at the plan. There's about an inch and a half of mounting block extending beyond the outer rib. I should have cut the mounting and used the offcut instead of gluing on a piece of 3/4" X 1/2" and drilling it. So much for trying to keep the structure light, now I've introduced a load of hardwood that's doing nothing at all. Perhaps I'll be able to use a cutting disc in the Dremel and saw it off.
30 Apr 2022 18:14 #25824 by Brian
The centre rib in the wing is about 3/8" thick. It has to be cut into three parts to accommodate the two dihedral braces. To help get a fairly accurate assembly of the three ribs parts and the two dihedral braces, I knocked up a jig from scrap balsa. While the glued up jig dried, I made a pair of aileron horns from 2mm epoxy glass sheet. These were sawn out using a metal cutting blade in a 1930s Hobbies fretsaw frame. This saw cost me the princely sum of 2/6 or 2s6d or "Half a Crown" (12 1/2p) way back in 1957. The chap who sold it to me really didn't want to sell it at all, only because the frame had slight traces of rust on it. I think perhaps he was persuaded to sell it as I was doing my National Service and was in uniform at the time, woefully short of cash, and it must have had some bearing on the deal.
14 May 2022 17:29 #25852 by Brian
Warm sunshine and the lack of wind today persuaded me to get on with the Moonglow's wing. I haven't made things easy for myself by sheeting the top of the wing first. Now I'll have to join the two halves with everything upside down. I made up two sets of cradles to hold the wings at the correct dihedral angle. These were made from scrap bits, and when the wing halves were supported on them and a straight edge applied to one main spar, the distance from the straight edge to the opposite spar was a tad over 1 7/8". The plan calls for 2" dihedral under one wing tip, I don't think the designer would quibble over 1/8". When I fit the sheeting to the underside of the wing, I'm going to try a method I saw on YouTube. In the video, the sheet was taped to the trailing edge of the wing. Lots of PVA glue was applied to the ribs and structure, the sheet was flipped over and was made to contact all the glued areas, then the sheet was flipped back and all the glued areas showing on the sheet were re-glued, as were the ribs and structure. When the glue had dried, the sheet was flipped over again, and using a steam iron and a piece of cloth (tea towel?), the sheet was ironed on. I think this must be a better way than trying to "pin-and-glue-as-you-go".
30 May 2022 07:52 #25894 by Brian
I don't know whether the following notes should be in "Tales of Stupidity" or something similar. Recently I've had a very ordinary common cold, first one for over four years. Apart from a runny nose, the only remaining symptom is a distinct loss of balance now and then. I should have known better, but yesterday I decided to transfer Moonglow's fuselage from the Winter workshop in the spare bedroom to the proper workshop (shed). I picked up the fuselage, turned towards the doorway and stepped into what seemed like a hole in the floor. Most odd! Even odder was the sight of the shattered fuselage after I'd picked myself up. Fortunately the top decking was only tack glued and ended up with only minor damage. First job will be to recover the ply formers and the engine bearers, I thought about contacting Belair to see if I could get a set of laser cut parts just for the fuselage, but I'll do that only if I can't make a decent job of rescuing the ply parts. If I have to rebuild the fuselage from scratch, there'll be one good thing, there won't be a brown edged dovetail joint right in the middle of the fuselage sides. No pictures, no point.
30 May 2022 12:03 - 30 May 2022 12:04 #25895 by Phil Ford
is a distinct loss of balance now and then..
I would be more concerned about the above than working on the Moonglow. :blink: Now you have even more problems to deal with. Although maybe your Cold has affected your ears balance "gyro"
Stories of Stupidity? Your choice.:lol:
Last edit: 30 May 2022 12:04 by Phil Ford.
30 May 2022 18:36 #25896 by kevinross
I think you have a touch of vertigo -my wife and son both suffer from it usually associated with an ear infection - the wise thing to do is contact your GP.
Time to create page: 0.438 seconds
