Fsky Taranis X9D Plus
8 years 1 week ago - 8 years 1 week ago #13922 by Phil Ford
Many thanks Chris. I think I see the bit I am overlooking. Yes i have used Companion 2 and also found you can drag an Input line down and then edit it to suit. I will have another play tomorrow. Companion 2.1.7 would not talk to Plus. Downloaded 2.1.9 and now it does. Now I can exit the bootloader properly.:)
I also think Stuart that your version is an early one because the Plus had some different coding.
Oi! What's all this formal greeting Mr Chris Wild......:lol:
Last edit: 8 years 1 week ago by Phil Ford.
8 years 1 week ago #13924 by
Should have said I programme on the Tx. As far as I know, the solution is the same with later firmware.
Stuart
8 years 1 week ago #13925 by
Hi Phil,
Glad you managed to get Bootloader, OpenTX and Companion all to the right versions to talk happily with each other, I remember going round in circles the first time I did it and cannot remember the exact route I took to get it done. I'm on 2.19 so that makes like easier. I'm by no way an expert, but if I can help I will,
8 years 1 week ago #13927 by
Phil, have you seen the new RX for gliders... built in Vario for the same price as an X8R
www.t9hobbysport.com/frsky-g-rx8-receiver
8 years 1 week ago #13928 by Phil Ford
No I had not seen that. I will have to get one of them or maybe two (got two gliders);) Hi precision Vario was £19 on HK. X8R receivers £30.
8 years 1 week ago #13929 by Brian
Hi Phil, I tried to understand the Taranis video on YouTube unfortunately the video id 53 minutes and my attention span won't cope with that timescale. However, there was a load of stuff in RCM+E a short time ago. I don't know if this will help.
www.modelflying.co.uk/news/article/opent...-to-install-it/23076
I think I might end up using my old 35 Meg JR stuff.
